tony powell
I have just purchased a MG ZS EV LR Luxury. If I plane a long route on the SatNav, will it recommend available charge points en route and update that information in real time if the charger is occupied?
Perhaps a daft couple of questions, but have you had any issue with the dongle draining the 12v, or do you take it out when you're leaving the car overnight? And does ABRP display like this via CarPlay/AAuto or are you using some other device?The onboard SatNav will not plan stops along the route :-(
ABRP is by far and away the best application for long distance travel in an EV if you’re driving a Tesla.
If you are able to give me an example of a trip I can put it in and let you know what it thinks.
I also use an OBD2 Bluetooth dongle that connects to ABRP to give accurate charge level info to the software.
I was hoping the inbuilt nav would have that kind of dynamic route planning, but judging by others posts it seems it doesn't, so I've been looking at options for when my car turns up.Not daft at all.
The dongle has no impact on the 12V battery when the car is powered down. I have the module for a few months now and left the car on occasions when on holiday with no problems when returning.
I use an Android AI Box that connects to the right hand USB Port. It has an inbuilt SIM Card Slot and Extended Memory Slot.
It basically turns the centre screen into a full Android Tablet and runs all the apps from its own memory. You can download and run just about any Android App, including Netflix, Amazon Prime Video, YouTube, etc.
I use the full Android version of ABPR with subscription and this uses the OBD2 interface as well as live traffic and weather conditions for its calculations.
Using the live SOC, ABRP learns how you drive and recalculates its estimations of range and stops required for any long journey trip.
Thanks so much for the detailed reply - really helpful!
Yes ABRP does display/work on Carplay/AAuto when used with ABRP subscription. If you use an OBD it will also link with that for live data but it is not necessary for ABRP to work.Perhaps a daft couple of questions, but have you had any issue with the dongle draining the 12v, or do you take it out when you're leaving the car overnight? And does ABRP display like this via CarPlay/AAuto or are you using some other device?
I note that ABRP still shows engie chargers (they are now geniepoint) around West Yorks as being free to use, but free use ended in October 2021...Another vote for Zapmap or check ABRP.
If you use Bonnet then their app is good.
The Electric Juice card is good as it has no pre authorization fees.
Which OBD dongle are you using?Not daft at all.
HeyNot daft at all.
Just try out AA/Carplay, it probably works for more than 50% of people without any bother, and not for the rest. It seems to depend very much on which phone you have and which cable you use, but even that is not consistent.I was hoping the inbuilt nav would have that kind of dynamic route planning, but judging by others posts it seems it doesn't, so I've been looking at options for when my car turns up.
www.aawireless.io
Michael, can I ask what Ai unit you have?Not daft at all.
Cheers thanks m82022 Carlinkit ai box 4+64GB
Some others on the forum are using it as well.
