wattmatters
- Sep 29, 2023
- Location
- Hungry Head, NSW Australia
- MG4
Two full years with the MG4. Here's the stats:
In March we moved home so I was doing a lot of towing.March and May are quite different in kWh/km, is that when the weather gets cold in Hungry Head?
Thanks, that explains itIn March we moved home so I was doing a lot of towing.
This was the first load being dropped off to my shed. I did 20+ loads.
Winter here is June to mid-August but it's not really all that cold.
| Period | Distance (km) | Efficiency (kWh/100km) | Average Speed (km/h) | Up Time |
| September 2025 | 1151 | 14.6 (4.26 mi/kWh) | 31 | 36:43 |
Impressive shedThis was the first load being dropped off to my shed.
I was impressed as well at how everything looks nice and tidy!Impressive shed![]()
If we travel and need to use highway DC fast chargers, then the cost is much much higher. Meanwhile a month of only charging from home is as cheap as chips. Cheaper actually.I must admit to not closely following your progress through this thread @wattmatters, but why is there so much variation in the $/100km, it ranges from as little as 4cents per 100km, right up to over $6 per 100km?
Seems like a fair bit of work but if you like doing that sort of thing then not an issue.If we travel and need to use highway DC fast chargers, then the cost is much much higher. Meanwhile a month of only charging from home is as cheap as chips. Cheaper actually.
DC fast charging has made up 16% of the total charge energy but is 58% of the total cost.
Excellent, thanks for the explanation, it all makes sense now.If we travel and need to use highway DC fast chargers, then the cost is much much higher. Meanwhile a month of only charging from home is as cheap as chips. Cheaper actually.
It's mostly automated. A couple of minutes each month perhaps.Seems like a fair bit of work but if you like doing that sort of thing then not an issue.
No, not with an ICE car because I didn't have Home Assistant integrations automatically collecting the data for any of my previous vehicles, and not for petrol/diesel purchases either.Quick question and not a pop in any way, did you do similar when you had an ice car?
Impressive cost effectiveness !
| October 2025 | 1623 | 15.4 (4.03 mi/kWh) | 32 | 49:19 |
Not sure if I can extract driving time from the data.Do you also have the average speed?
