grange
I won’t say this is a fix to the problems associated with lane keep assist, and those that keep turning it off each time they get in the car, but this is a solution I have been using to make it work “normally”.
If you try it, and it works for you, come back and say so, so that others can get value from this.
So what I have tried, and now doing is the following:
1. Don’t turn off lane keep assist
2. Turn off ACC and TJA in the menu.
3. Just get in and drive the car as normal.
ACC and TJA will stay off each time you get out of and lock the car, and as we know, LKA will turn on each time you get back in, but that’s ok, so when you get into your car, you won’t need to touch the screen at all to change any settings,
Just get in and drive.
This solution has made LKA work as I expect it should.
I don’t use ACC or TJA, and I think most people may not use it often either for daily drives, so give it a go, and if you want to use either at anytime, just turn back on, but you will probably get the associated problems with LKA back.
Good luck….
Good luck….
