That's good to know, one of my regular trips is 250 miles, so possibly I could do this without needing a public charger.My ZS LR was bought new in Jan this year. Firstly it's been totally reliable. Everything functions brilliantly & it's great to drive. Secondly, it's range is really good even in this cold snap. I fully balanced charged to 100% at -1c & the car still showed 299 miles in normal mode. Eco showed 308 miles. I believe the battery heating may have come on during the charge. But I'm not sure. In my running about over the last two days ACTUAL range has worked out to just under 260. That was taking the battery down to 21% & extrapolating the last bit of range. I don't normally take the battery down to very low percentage figures as it's not a good thing to do by all accounts. My mileage over the last two days has taken in A12/A14 cruising at 60mph (much better range at 60) & town & country road driving. In summer the car easily exceedes the WLTP figure of 273 miles by some way. It's all good.
Why little or no regen? Is it because the ACC will brake rather than use the regen when going over the set speed? ie, going downhill.My LR ZS has averaged 3.3 miles / kWh over 5600 miles since Jan.
Tuesday it was very cold, windy & raining when I drove up the A14 to get a new windscreen due to stone damage.
I guess 20 miles each way at 70, I live 1/2 mile from the A14. Heater on , lights, AC & wipers. I got 2.6. I used ACC so little / no regen.
I went the next day shopping via the back roads so 30-60 mph & got 3.
When I see my son in London I can get 4 plus due to the low speed.
To date with a mix of home charging & external I'm paying 3.4 p per mile.
So charging to 100% & down to 20% at 3.3 m / kWh my range is 75x3.3x.8 =198 m and at 2.6 m/kWh it is 156 m
Thanks,ACC on the ZS only uses the brakes to reduce speed, a hangover from being a ICE car.
Yes, that's right John. A good example was when I went to 'Everything Electric'. For me it was a 250 mile round trip. I set out with 305 miles of range in normal mode at 17c. 315 in Eco. On the way home when I'd hit 30% state of charge I decided to pop into South Mimms on the M25 just to top up the charge & get a coffee, cake & a wee! As these longer trips are still something I'm getting used to my thinking was if I ran into a diversion adding 15 or more miles to my journey I might run short of charge. So a 20 odd minute charge was added during my 30min stop adding 140 miles to the tank. Didn't need that much but was too lazy to run out & stop the charge & disconnect to avoid an idle charge.I think Data is quoting 100% of the battery being consumed. Realistically I wouldn't normally go below 20%. So 250 miles would be hard to hit.
Get the electroverse app it will plan your route and tell you where to charge and by how much to get home with 20% left.
Normally that is time enough for a loo break
Another app that is not so biased in terms of charging companies is ABRP 'A better route planner'.Get the electroverse app it will plan your route and tell you where to charge and by how much to get home with 20% left.
It's ok trogg. It's really not needed on longer motorway trips or when cruising at these higher speeds. Even if driving without cruise switched on the regen hardly gets used anyway. For me regen is virtually useless under those circumstances. It's great everywhere else.Thanks,
That's a shame, I was looking forward to using it.
If you charge with an Electroverse RFID card you pay your money to the Electroverse charging network. Example: Osprey charger at Elm High Road, PE14 0DQ Electroverse price 87 pence,Dave Said: The Electroverse app is not biased.
Roldorf, it's seems to be different here in the UK. Over here it doesn't matter what charge company you charge at using the Electroverse card. We all get at least an 8% discount (see update below) off the charger price when we use our Electroverse cards. We also get 'price plunging', a heavy discount of upto 40% off the charge price on certain days & at certain times. It's very good & seems to beat most other schemes out there. I appreciate it might be different in Germany. Also the Electroverse app will take you to any charger you want to go to. Part of that is our charging network here in the UK is becoming very advanced. Most charging companies are signed up to the Electroverse scheme. They did this so as not to miss out on business as it's one of, if not the most popular payment schemes. Of course Octopus earns money out of it. They all do.If you charge with an Electroverse RFID card you pay your money to the Electroverse charging network. Example: Osprey charger at Elm High Road, PE14 0DQ Electroverse price 87 pence,
MFG Charger at Clipbush Lane, Fakenham NR21 8SW 79 pence.
The price you pay to Electroverse/Octopus is the Osprey/MFG price + the charge taken by Electroverse for listing them in their app and using the Electroverse RFID card.
I have an Electroverse card and an Ionity card. At the same Ionity charger Niedersachsendamm 2, Delmenhorst 27751 Germany, I pay 59 cents with Ionity and 70 cents with Electroverse.
Who do you think gets the extra 11 cents?
So of course it's biased, as it wont take you to chargers where it doesn't get a kickback from the charging operators.
