I had another good one yesterday, not an emergency brake application but the ACC bringing the car to a near hault before I clicked it off and continued.
I was driving down a 30mph zone, very little traffic and quite long, hence the cruise usage. The road widended out allowing parking on both sides but still having full width lanes. The car obviously saw the parked cars on my left and assumed a traffic queue and decided to stop the car. I let it do its thing as there was nothing behind me. It was quite disconcerting on a wide road, I'd have of understood if I had gotten too close to a parked car but the distances involved were considerable.
My GF looked at me wondering what the hell I was playing at, I just laughed and explained the car did it by its self.
A quick flick of the right indicator, as you approached the parked cars, would have prevented this.
And this is where they calibrated it to the edge of the road.
Mine must be unique, am I the only one who's not had it engage, I've had a warning beep a couple of times but it's never actually braked.
Not unique, as neither have I. The LKA, even on the default, is very mild - the only issue I have with that is that it seems completely random, I can drive over miles of white lines, and it will not complain, then suddenly twitch with no lines at all... huh? But it's no big deal.
I've not had any sudden braking...
I thought LKA was a bit random at first until I found out it's speed related.
It turns off under 35mph and comes back on at 35mph and above.
Quite normal, but only when ACC selected around town (like this) - never used acc in town for past 12 months
They aren't close though, I didn't have to manuovre around them I was travelling in a straight line.
Sadly I think my next car will an older one converted to EV; I love technology until it gets in my way.
Yeah, it should not have gone off there if you were on the right hand side of your half of the road. I suspect it may have seen those shiny marks on the road where the tarmac overlaps and thought they were lane markings.
I've only had it "slam on" once the first day I had it.
In a village, van delivering my side, just went to drive around (nothing oncoming) as I usually would, car tried to break both our necks!! and made me look like a right twonk into the bargain!?
I now religiously indicate (regardless of if I have someone to indicate to) so the car knows I have seen the offending vehicle and am taking my own measures to avoid crashing into it!
AFAIK, the radar "alignment" process is just self learning! They drive it along a straight road (which apparently needs regular posts or obstacles either side - good luck finding that road) and stay within a specified speed range then give it back to you.
Hi, do you have a reference for this? It potentially gives hope that the cars will improve over time by themselves. I’d got into the routine of turning off the collision avoidance and LKA settings at the start of each journey, but they no longer stay off. This also suggests that either a software update has happened over the air or a bug has caused the software to function differently.
I get the same thing if I'm using the ACC to handle a 20 mph speed limit, even with no shiny marks on the road. Sometimes it just decides that parked cars are an issue even if there's plenty clearance. I just use the accelerator to push past it. I've noticed that if I'm following another car it usually doesn't do it, presumably because it sees that the other car (which it is locked on to) is getting through.
This happened to me just the other day, approaching Morrisons roundabout in Dumfries. I was just moving on to the roundabout at no more than a 5MPH and it slammed the brakes on. ACC wasn't engaged nor LKA. No traffic in the way, no pedestrians. I spoke to the dealer and it had happened to them as well. No explanation given.
Does the front facing camera play a part in emergency braking?
I've also had the ACC pick up parked cars and brake hard, this used to happen with the KonaEV I had before.
Yes it does, together with the LIDAR (?) sensor low down on the front of the car. The camera detects object type (with a rough estimate of distance) and the sensor detects more-accurate distance.
I believe there are software updates available to address issues with these devices.
Not had this yet, only a few warning alerts when approaching a parked car / van or series of parked cars on either side of the road where you have to zig zag. As soon as I get the alert on the screen I always react by braking a bit or adjusting the steering a bit more away from the first obstacle. On VAG cars this always avoided the car thinking you were not aware / or reacting and hence the very sudden emergency stop was avoided.
Not sure with MG yet but are any of you getting the alert first and then the emergency stop ? or just getting the emergency stop with no prior alert ?.
I’m from Australia, just got my 51 excite (your 51sesr) I guess. It braked hard with no object in front and freaked my wife and myself out. Photo below for reference. Maybe it picked up the bins, or the car on the verge, but that’s wayyy too sensitive. How do you guys find out if there’s updates? Very frustrating not to have OTA and only dealers can update.
I have the equivalent car, driven nearly 5,000 miles, and that has never happened. The ARB activated once, but there was a reason - a man had stepped out on to the road from between two parked cars. He was only going to open his own car, but I think my car thought he might be about to walk right in front of us. I can cope with that sort of thing once in a while if there is the potential for it to avoid an accident.
I think it activated another time as I was drawing up behind another car waiting at road-works lights. The ARB came on simultaneously with me braking myself, but I don't think I braked that hard. Again, that's only once, and it didn't even faze me. I think you may need some sort of adjustment to camera or sensor or however it works.
Yup the emergency braking happened within the first week of ownership (Trophy with rear wiper model). Wife was driving about 30 in a 40 zone and next minute car was in neutral, handbag was in the passenger footwell (had been on seat), and the wife was a bit bemused
Thankfully the car behind was some way away, though he did beep his horn (likely to say why the hell did you stop on an open road)!
There was no car in front and no traffic coming the other way. She thinks it was shadows (of trees) on the road that the car saw as an obstruction
Setting is now routinely manually set to off every time we start the car.
Have managed to not hit anything in 80 years (wife and I combined) of driving without nanny aids, so hopefully can continue to be safe without
Just had this for the first time. Manouvering to turn right, no cars, no people. Nothing.
Jams on the brakes - felt like emegerncy braking in driving test. Stopped car.
Car completely misread the scene in front of it.
Hmmmmm. and if something hit you MG would be responsible !!
    Votes: 1,052 77.9%
    Votes: 204 15.1%
