MG ZS EV - Vehicle to Load - adapter not recognised
SignallerBrian
Didcot
I have just purchased an V2L Adapter from Amazon which states it is compatible with my 2023 ZS EV.
When I select my discharge screen I the following is shown which looks correct...
When I connect the adapter to the car, I get the following message:
Am I doing something wrong or is the adapter rubbish and I should just return it. If so can anyone recommend one that actually works with the ZS EV please?
Thanks,
Brian
To me it looks like your adaptor has the wrong resistor value inside.
There is a resistor inside that tells the car what kind of cable is connected (And if it is a charger cable, it also signals to the box on the wall, how much current it can handle)
If they put the wrong resistor inside, the car will think this is a charge cable, and not a discharge adaptor
Look at picture 4. It is a multi socket and takes a uk plug
It is the socket part. I leave it with you.
I can't be certain looking at the socket, and I would have expected an image of a UK plug as they display a range of accepted plugs. But if you have this actual item and have plugged in a UK plug, then I'll take your word for it.
Thanks
elkay62
some 2023 cars need V2L fixed, before you buy from that guy on eBay, make sure you tell them what car you have and ask if you can return it if it doesn't work on your model. Mine is 2022 and it works. Have a look on other threads about V2L on this forum
Thanks, I spotted those threads, though it isn't clear if there is a way to identify if V2L works without trying an adapter that you know is reliable.
I've sent a message to the eBay seller, but will probably go ahead and buy, and if it doesn't work hope that the dealer can sort it for me - we have a connection.
I've just traded my MG5 in for a 74 plate ZS Trophy Connect and the only issue is a non functioning V2L using an MG specific adapter with UK outlet bought from Ebay.
When plugged in I get the 'Discharge adapter not plugged in screen' but the car itself knows that something is plugged in because I get the 'can't drive' message on the speedo screen.
So, I trundled to my dealer and they plugged my adapter into a same model car and - lo and behold - it works. The car has now been through the workshop at the dealer and had the latest software updates and errors checked and cleared and still no joy. They have put a call out to MG Technical but said it could take days/weeks to get a reply (is that good enough?).
Any ideas, anyone?
Probably fitted with the wrong inverter. Was the car sold as having V2L?
It may not work, but try plugging the cable in before opening the discharge screen.
The car may recognise it if it is plugged in first
Try stuff like doors all closed and locked too. There are some vagaries in software that we sometimes have to play around with.
We have a Gen 1 ZS EV so no VTL for us
Thanks,
Brian
Hi did you ever get your car discharging?
I am having the same problem.
Thank you
Kerry
Mine still not working. It went back to the dealer a couple of weeks ago for diagnostics and they referred it to MG Technical. They told me today that a part has been ordered - I didn't get to find out what the part is! Watch this space...
Just in case anyone is encountering the problem highlighted in this thread...there is a separate thread that discusses the issue with V2L not working on some MG ZS EVs, depending on the EVCC used at manufacture. This link takes you in at an appropriate point:
In my research, the EVCC is critical:
Non-working part number
11408732
Working
11349836
11505199
As mentioned in that thread, it appears that some cars built in 2023 have the non-working EVCC.
There are photos on the thread that show what the plate with the partnumber looks like.
Thanks,
Brian
Latest update - nearly a year later! I got MG to test my car on the last service in October 2025 and they confirmed it did have the wrong inverter. After several weeks they finally got authorisation for this to be replaced under the warranty and that is happening today!! I will further update when it is completed and I have tried it with an adapter which I now need to re-buy!
