pauljohnson
- Jan 12, 2024
- Location
- Stockton-on-Tees
- MG4 Trophy LR
Charging lights not working
Yes, but look at @siteguru post above for likely fixes.Will I be able to do schedule charging from the Wall box without the charging lights working?
How do you do this? I really appreciate your help.Just search this board - this has been discussed many times. There's a fuse that can be pulled out and reinserted and that usually fixes the problem.
If you don't want to pull apart the trim to access the fuse then the same can be achieved by disconnecting the 12V battery for a minute then refitting - but you'd need to recalibrate the steering wheel and window motors sensors afterwards. (Easy to do).
