Mg4 charging lights not working
Just search this board - this has been discussed many times. There's a fuse that can be pulled out and reinserted and that usually fixes the problem.
If you don't want to pull apart the trim to access the fuse then the same can be achieved by disconnecting the 12V battery for a minute then refitting - but you'd need to recalibrate the steering wheel and window motors sensors afterwards. (Easy to do).
How do you do this? I really appreciate your help.
Which specific point are you querying?
You use this to do a search - select This Forum from search area options.
    Votes: 544 79.2%
    Votes: 92 13.4%
    Votes: 51 7.4%
