MG4 Charging power 0.0kW
On mobile so unsure what version of the mg you have.
Can you schedule in the cars settings? It's under the main menu, battery then tap on the cog I believe as well as set limits if on a trophy.
It might be worth clearing or adding schedule via the car only and ignore the charger just set it up and connect and let the car do the charging?
It has the same issue no matter where I do the schedule unfortunately car or charger. I have found one thing and not sure if it makes sense to anyone. The past 2 nights I've had successful charging. The only difference I made was, I set battery preheating 30 mins before the charge started. I've tested again today without battery pre heating and I've had the 0.07 kW issue again. Anyone ever seen battery pre heating needed to charge properly? Wondering if actually it wakes up the car to allow the charge.
It may be that your car was going to sleep in that last half hour, and any activity (e.g. lock doors) at that time might have woken it up. Just a thought.
….. I have is a Project EV Apex charger.
I’m using a Evnex charger.
It has a setting ‘keep the car awake. During charging’. I don’t think this is necessary for all makes but is currently recommended for MG’s.
So this might vary from charger to charger 🤔
I've checked my app and it doesn't have this setting. I've called project EV who have said the setting to keep the car and charger talking whilst waiting for a charge is already enabled. I've got the car booked in with MG to check it over for software updates and also the charging company to come back out to do some checks. I feel like this must be an incompatibility between the charger I have and the car I have as it works fine on a granny charger when scheduled on the car and also from another 7kW charger I've tested on.
Have you tried a full disconnection and reset of your wall charge point ? I suspect it's that or some settings on it or just incompatability as you say, as the car charges and schedules OK on other chargers.
Project EV came out and swapped the charger out for a brand new one which has the same issue. I really feel like its an incompatibility between the two. I guess I'll not know any more until the car has been in to MG. Any other tips from people are always welcome though as its a massive pain
I have a charger that look suspiciously like a projectEV unit (vchrgd7). I once had a problem with scheduled charging. Long and short of it, I isolated it to powerline networking kit in my house. There is a thread somewhere on here where I posted.
I removed ALL powerline networking kit and voila problem gone. Not saying it is you issue but worth a mention.
I think you're the first person here to confirm having 1300R63. Anything obvious about it? (Good or Bad)
Seems decent so far. The only downside I've found is I only seem to be able to change the charge % from the app and not the car anymore but not too much of an issue. Other than that it's all good
Thanks mate. The firmware updates sorted this out for me
Something in my memory says you have to slide the %age charge bar in the car rather than tapping the screen. Have you tried that?
I have this exact problem! MG4 EV charges fine if plugged into the Zappi on a sunny day, so charging under eco plus rules. It also charges on any other charger, including the granny one. But when intelligent octopus go schedules charge, I get the 0.0kW charge issues. The car thinks it’s charging, the octopus go app thinks it’s charging, but no charge is being added! Super annoying. I’ll look into that firmware update you mentioned. Thank you for posting this, I’ve had the issue for months & googled it without finding anyone experiencing the same. It’s been driving me crazy!
Just tried unlocking & relocking it & it worked! Now charging properly as per schedule. It’s like the car won’t wake to charge unless you poke it? Really appreciate everyone’s advice on here. I’ll ask the garage about the firmware. Maybe the zappi isn’t sending the right signals.
Charging won't work if it's in ready mode. you have to lock and unlock to get out of ready.
That's not true in my experience.
Indeed, I can't think of a time when I've charged and the car hasn't been in ready mode.
A few times it has had to be in Ready mode for you to tap the "start" charging icon on the infotainment screen if the charging session hasn't automatically initiated.
After it's kicked off, then you can lock the car turning it off and wander away...
    Votes: 1,070 77.7%
    Votes: 208 15.1%
    Votes: 100 7.3%
