- Jan 31, 2023
- Location
- France SE,LR23
- MG4
In the user manual under emergency headings it shows "changing the spare wheel " which of course it does not have. Having not received my car yet, and not being observant enough on the test drive , does the car come with a jack and wheel brace? If so how is it possible to raise one of the rear wheels and rotate it . I,m guessing that it would have to be in neutral and manually switch off the handbrake but leaving the car powered on. Yes I have chocked the front wheels! Would the car automatically switch off after a period of time and apply the handbrake ?
This method would make fixing a rear puncture easier as you could locate the affected area and place it at the lowest point before applying the sealant , also giving the tyre an easier time when reflating especially if the bead has come away from the alloy.
Or is it easier to ring MG assist????
