Rob875
My MG4 SE LR has done 35,000 miles and I usually charge at home using a ProjectEV 7kW charger in dumb mode. I set the timer in the car to charge between midnight and 7am to take advantage of my Economy 7 rate, normally charging to 80%. On locking the car I check through the window that the display is showing "Charging Scheduled".
On a few occasions I have thought the car started charging immediately after setting the scheduled charging, i.e. several hours early and on peak rate electricity, but I was not sure that this had actually happened. Today I have had a smart electricity meter fitted, and plugged the charger in on a scheduled midnight charge to check that the charger was still working working OK with the new meter connections. Despite seeing the "Charging Scheduled" message on the dash, and checking the timer was set with a midnight start time, the car started charging immediately. I then unplugged, reconnected, and then all was OK, with the car showing "Charging Scheduled", but not yet charging.
Has anyone else seen this premature charging issue?
