Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
Well and succinctly put.
why would you want the HVAC to stay on ?I'd like them to fix the bugs in the existing software first.
On the SE.
1. The USB music player is essentially useless because it lacks the facility to handle folders which the Trophy has.
2. The radio (well, the sound system) comes on whenever the car is woken up, even if you turned it off before you got out last time.
3. The auto-locking can't be disabled.
4. Update R16 added a new bug - it removed the outside temperature display from the central screen.
On the Trophy.
1. The LKA comes on when the central screen switches between light and dark modes, even if you switched it off before moving off. (If this has been fixed, maybe a Trophy owner can say.)
2. The HVAC screen vanishes a couple of seconds after the star button has been pressed. (Some people say they like this, I have no idea why.)
3. All the unpairing of phones, screen instability and so on that Trophy owners have complained about.
On both versions.
1. The pre-heating/cooling from the app doesn't work if the car is plugged in but not charging. (I thought someone had reported seeing a fix for this?)
2. The HVAC temperature control reads 5 degrees higher than the actual temperature reached at that setting.
3. The lights come on if the sun goes behind a cloud unless you take the cover off the sensor.
4. The state-of-charge indicators on the central screen are obviously meant to change to amber when the charge is getting low and red when it's very low (there are videos of cars doing this) but other than occasionally changing to amber at random times (including 100% charge), they stay green.
I've probably missed some. Vague reports of cars where one or two of these problems have been fixed, but pretty much all cars still seem to have them.
I have tried to explain why the Trophy behaviour can be desirable. Let me try again.In the SE the HVAC screen appears when you press the star button and stays there until you press the star button again. This allows you to see what you're doing when you're altering the temperature and the fan speed, then dismiss the screen when you no longer want it. You can still do it all without looking at the screen if you want to, and pressing the star button again the second you're done adjusting the settings will get rid of it. It simply means the screen doesn't vanish while you're still adjusting it, and you don't find yourself in the position where you're looking at the home screen, but the car still thinks you're in HVAC mode when you next try to change the radio volume.
It seems entirely intuitive, and I'm baffled as to why Trophy owners say they're happy that the screen vanishes on its own after a couple of seconds.
But once you press the star button you can just use the joystick to adjust everything...left/right is fan speed which takes it out of auto and up/down the temperature...pressing the joystick selects Auto again....It's about the best feature of the entire home software..I used it many times during my trip ?In the SE the HVAC screen appears when you press the star button and stays there until you press the star button again. This allows you to see what you're doing when you're altering the temperature and the fan speed, then dismiss the screen when you no longer want it. You can still do it all without looking at the screen if you want to, and pressing the star button again the second you're done adjusting the settings will get rid of it. It simply means the screen doesn't vanish while you're still adjusting it, and you don't find yourself in the position where you're looking at the home screen, but the car still thinks you're in HVAC mode when you next try to change the radio volume.
With the R46 sw also the trophy behaves like thisIn the SE the HVAC screen appears when you press the star button and stays there until you press the star button again. This allows you to see what you're doing when you're altering the temperature and the fan speed, then dismiss the screen when you no longer want it. You can still do it all without looking at the screen if you want to, and pressing the star button again the second you're done adjusting the settings will get rid of it. It simply means the screen doesn't vanish while you're still adjusting it, and you don't find yourself in the position where you're looking at the home screen, but the car still thinks you're in HVAC mode when you next try to change the radio volume.
Yes, that's exactly how mine works too. It just lets me see what I'm doing if I happen to want to see.the
That answers which is the intended behaviour then. Thanks.With the R46 sw also the trophy behaves like this
I'm still on R13 for my SE LR. Absolutely sick of Android Auto crashing every 10-20 mins. I don't do any commuting so the majority of longer drives require sat nav. I have to rely on my passenger to unplug and replug in my phone every time this happens. Unacceptable performance. Other than LKA I love the car, but this issue is extremely frustrating to deal with.
Oh come on, it suggests that the SE behaviour is the right one, I thought you'd be happy about that, seeing as everything SE is clearly wonderful! ?Not necessarily. Still, if you're happy.
Let's not forget it could be worse. Here is a report on another manufacturer applying a software patch to what appears to be a physical problem, and a very important physical part too.Let's start a rant about the lack of updates, OTA upgrades, and extensively compare how other brands issue and deploy them (or not) and criticise the annoying bugs we find in the car and the iSmart app.
Please, write your comments in this one and not in the MG4 Software Updates thread which is just to track the latest version for the different trims.
I am fed up of the R30 navigator freezing the screen as it makes me miss many turns!
Ford’s recall of Mustang Mach-Es in 2022 is under investigation by feds
There have been 12 complaints of power loss following the software update.arstechnica.com
