T1 Terry
- Feb 7, 2024
- Location
- Mannum South Australia
- MG4
I think those energy charging figures are what was fed into the vehicle from the charging point, not what actually went into the battery. Is this correct?Could this explain why the first owner of my car lost SOH around 6%?
when i bought the car
Soh:93.64%
10500 km
now(3 months later):
Soh:92.9%
21500 km
(SOH values were checked after a 100% balancing charge from a low percentage. I don't know how accurate it is.)
And is the 41.6 kWh value the value that will settle over time?
I would also like to state that I loaded 40.7 kWh energy from 3% to 83% last night. I also remember loading 45-46 kWh for balancing.
Allowing a 10% inefficiency between supply and actual battery input, that comes out at around 36kWh into the battery. 80% of a 42Ah battery is 33.6kwh, fairly close, 2.4kWh difference ..... If the battery capacity was really 51kWh, then 80% is 40.8kWh, meaning the efficiency between the supply and the actual energy going into the battery was better than 100% .... I know which is more believable .......
As far as balancing, the system MG use is a loss method by burning off capacity as heat through resistors, and all the time that is happening, the inefficiency losses within the charging system remain, so the energy used during balancing is far greater than the energy actually added to the battery.
T1 Terry
