MG4 Software Update Thread
What to do?
Do not buy ever again an MG, and tell everybody how bad is the customer service in your country.
That's the only way to avoid bad standard practices to spread; the "all the brands are the same" denial just makes things worse.
A good customer service does not make you waste time arguing and raising formal complaints about an obvious defect.
Getting things done by suing is not fit for Western societies.
MG should get their shit together and let us update the car ourself trough wifi. The car was sold as being able to update it ourself. It was a lie.
What do I do if my dealer refuses to do an update unless their diagnostic shows a fault? I booked it in with multiple issues, screen going blank, Bluetooth loss, volume maxing out at 6 and AC thermostat way off but it needs to show up on the day before they do anything as "an update when it doesn't need it could cause a problem."
Your volume is stuck at 6 after reversing? There is an update for the shifter that solves that issue.
How long does it take for the dealership to upgrade the system?
My English mecanic (yes here in Norway ?), told me that each module he had to update took him half an hour. That's why my service went to 4 hours instead of the normal 2 1/2 hour.
P.s. No r59 in Norway and I can from experience say that the Norwegian MG importer plays it safe with the updates, not wanting to put anything in to the cars before proven reasonable safe.
Mines going in on Tuesday for a replacement passenger door handle and the updates they didn't do for some reason at the service in March.
I've mentioned that the infotainment screen sometimes goes blank when switching between light and dark modes and that the Bluetooth is terrible so it'll be interesting to see what R number I end up with.
I just picked up a new mg4 and it seems to have an issue with the sound system. System sounds sound good, but any music from radio/bluetooth sounds quiet and muffled. Really weird, have it booked in to see what’s going on. Also has the phone Bluetooth disconnect on each startup.
Oh, forgot to mention that the mecanic can't do anything else with the car while it's updating.
I got the impression that he was not very impressed with the MG update system.
It’s MG 4 trophy long range. Got delivered on r40
The sound system the Trophy is not bad at all, but the default settings are not good. You need to turn on the virtual sub woofer, turn on the 3d setting and also turn on loudness. Then have a play with the graphic equalizer to your preference, also make sure all speakers are on as you can turn off the rears.
Thanks Andy. Already did all of that as I had another pre facelift one before this. No joy however. Almost sounds like the front speakers are quieter than the back ones.
Suggestion: bring both of them back to say 4 and add more radio volume with the buttons.
My cable box also does not support max Audio volume out. Is was supposed to protect the hardware of the box. I think it is bullshit, as the sound is amplified elsewhere.
Thanks for the suggestion will give it a go. I have booked it in for software update to get the Bluetooth disconnect sorted.
Multiple confirmations of it being there for people on R59.
It's on the swipe-down menu on the homescreen.
Or at least it is for other people on R59...
On home screen, swipe down the top-left corner to see the quick launch options. One of them should be "ELK Disable" or "LKA Disable" or "LKA Off" or something like that.
e: from earlier in the thread:
is it possible to disable the FCA via quick launch option or add any other features to be enabled/disabled by the car owner?
Just sent this to the dealer I bought the car off, ahead of approaching Santander finance with a Satisfactory Quality Complaint. I think reading between the lines, and the fact I'm even sending them such an email in the first place kinda highlights my position.
I am very tired with the car, and not happy at the thought of spending another year and a half plus with the PCP at the rate the car is improving (no where near quick enough).
I will see if they do anything, but I am expecting a fob off, in which case I will take this up with Santander, as at this point, I feel the worst offending MG EV4s are basically faulty on software level, especially as you cannot turn the TJA/LKA off permanently, and I should be able to use a function of the car I've been paid for, radar and lane assisted cruise control were a big part of this for me; as I often do long days, and motorway miles.
After my previous Ioniqs, this car has been a MASSIVE dissapointment, and am distinctly considering just dumping it if I cant get anywhere with the dealer or Santander PCP finance. Maybe give BYD a try, they are chinese too, but the software sounds far less half-baked than MG, and they actually have OTA updates (and a heatpump, which oddly enough matters in the UK winters).
Honestly the false braking and lane fighting are the worst parts though, as they go from annoying to actively dangerous; I've had the car slam brakes on on me now numerous times, because its misjudged a parked vehicle which isn't even in front of me, or with no obvious reason at all.
I am very tired.
Hi there,
I am reaching out to you as directed by MG and Santander regards my EV4 as the original supplying dealer.
I have had no end of issues with the car since purchasing, worst of which have been numerous occasions of dangerous phantom braking sometimes at 30mph or over, or forced car auto steering for no reason which have almost caused crashes on multiple occasions, and have caused great concern to both myself and my wife.
To try and resolve these issues, I have been to local MG branches for software/firmware updates already twice, and am due to go in for a third time tomorrow, and have been in contact with them even more regularly than this because of the issues.
On top of this the issues have been numerous, but not restricted to:
Onboard electronics crashing
Working car chargers refusing to work with the car (I know they're working as I've watched over cars pull up and use them)
Faulty/System error notifications and elements of car being disabled until car is powered down and rebooted.
Infotainment system stalling and crashing, or previously sometimes refusing to produce any volume
Onboard screens failing to boot
Bluetooth regularly disconnecting (it is now rarer after some of the updates but still does this intermittently)
Temperature system sometimes refusing to heat up or cool appropriately and generally seems way off at times.
On top of that, MG's promised OTA software/firmware updates have not materialised.
Efficiency from the car has often been noticeably poor, around 3 miles per KWH.
ECall system faults
Autohold faults
And these are just the ones I can remember right now.
I am reaching the point of having to consider alternatives only a year and a bit into a PCP, which I have never done previously, but this is making me seriously unhappy with the car in a way that I have never been previously, the car has been a horrendous disappointment coming from my previous Hyundai Ioniqs.
My wife now believes the car to be dangerous, and refuses to drive it; and believes I should be able to return the vehicle.
Ideally I'd like to return the car at this point, as I have already been to local MG dealers more times than I can justify, and the issues have not yet been solved. As I stated when I bought the car, I needed something reliable for my workload, and the car has unfortunately just been unreliable and periodically unsafe; the last thing you expect from a new high tech EV, and a absolutely massive disappointment after my previous Hyundai.
Throw in the top the previously promised MG OTA updates have never arrived, and it generally feels like at least the initial version of the EV4 for UK/Europe was half baked and is being abandoned already (I note there has already been a mini-facelift with some tweaks including rear wiper).
Regards
I am very tired.
Hi there,
ECall system faults
Autohold faults
Regards
Last paragraph
EV4 -> MG4
    Votes: 1,084 77.8%
    Votes: 208 14.9%
    Votes: 103 7.4%
