MG4 Software Update Thread
You can adjust the regen setting so that it's not so intrusive, gradually slowing down over a longer distance, still good regen, lower setting but over longer distance and a lot more than no regen.
The previous three posts illustrate why I never use ACC if there's traffic in view in front. In my previous and present car's, I would have lifted off or "feathered" the accelerator, long before the ACC would kick in.
When changing from regen 3 to 1 whilst on the move on partial throttle you can actually feel a very short slight surge. It almost implies that there is a very slight drag due to regen on a part open throttle all the time ?.
It does. But by reducing the ACC speed setting manually (1mph decrements) after looking ahead prior to the ACC reducing the actual speed means the speed reduction is not so severe when the gap begins to close.
Currently I’m not able to use ACC. I thought I’d sorted the issue of sudden slowing by turning the settings to ‘Alert Only’ (No AEB). But alas this mornings run out with the pooch resulted in sharp slowing down from 80kph to 60kph. Just after a curve in the road heading in a straight line, between well marked lanes. Maybe it was the cement truck coming the other way, that scared it. Anyway…. The pooch was strapped in, as per common sense and Queensland regs, and there was no one half asleep behind us.
Definitely unusable in my area.
It’s a shame you can’t as a user, choose which items are under the ‘Unswitchoffable’ AEB and which are not.
Yup I’ve noticed this too. You can also feel it when in eco mode you switch on OPD. A definite drag feeling. I find OPD in eco mode quite lumpy. It would be nice to know exactly what’s going on so that I can drive with knowledge rather than poking and hoping ?
Question for AU/NZ Excite 51 owners... has anyone received an update later than R05?
Or alternatively any other update that fixes the issue where the left star button on the steering wheel forgets its setting (and the one on the right always open CarPlay in addition to whatever it's set to open)?
Nope, mine came with R05 when it was delivered in Sept last year, it's been back for both the One Pedal and the braking updates and that part never changes.
The star button thing is just a joke at this point.
It's been driving me mad this Winter how we don't have any sort of auto or time based brightness control for the main screen either.
In Europe, the slowing in curves and bends are cured by an acc update. Shame they do not hurry up down under..
Same with the star button btw.
Yes, and annoyingly they have released that same update months ago in Australia… but only for the Essence (I think that’s the ‘Trophy’ in Europe/UK?) and not for the Excite (SE SR) ?
How do I find out the latest update number/version with improved ACC for the Essence? I've got a tailgate warranty issue being sorted in a couple of weeks. I could get it checked then.
In the UK this was fixed under update SCUK001, but I've no idea what the equivalent AUS update would be. It is not however linked to the Infotainment version (although they may apply such an update at the same time).
You know if you have the ACC update as a single toggle up/down of the left joystick changes the speed by 1 rather than 5 (mph/kph).
Oh that’s annoying. I definitely have the ‘toggle’ thing.
Oops, sorry had a brainfart there with my reply - I meant although I have the ACC update, I don’t have the Star Button fixes.
My 51 got that update last time it was in, while they also did the undertray support.
I've heard it referred to as the AEB update.
I got the ACC/AEB and Undertray fix too, so at least no dramas with that…. But yeah the star buttons and CarPlay occasionally switching to LHD mode (which is read from the head unit and not controlled by CarPlay) surely would be easier fixes, which is what makes it so frustrating putting up with them ?‍♂️
Hi all, i have an 23 plate MG4 SE SR. Just took it into the RRG MG as it had a myriad of issues.
1. EBS kicked in for no reason nearly causing someone to go into the back of me.
2. HVAC would intermittently not kick in heat unless you set it to high was still blowing cold even on 32 degrees.
3. Android auto buttons overlapping since service / last update.
3. Fault with door mirror though this was just a loose wire.
Part of the fix they updated the MPU version to R33 but said they do not update the MCU version so it is still on 69.1.1.1 is this correct or should they have updated both.
Since update the HVAC is still not working correctly and i have a new fault. The left * function key will not let me register anything to it.
Anyone has these issues themselves and can advise if they should have updated the MCU version?
Edit: I live in the UK.
    Votes: 984 77.6%
    Votes: 187 14.7%
    Votes: 97 7.6%
