MG4 Trophy/Luxury replacement headlight - is this one OK?
Starplots
Bansha, Tipperary
A question to anyone who has changed a Trophy/Luxury headlight - left or right doesn't matter!
I need to change a headlight as I punched a hole in the front of it (headlight meets steel post box, the post box won :( )
I sourced an immaculate new right hand headlight from Latvia - the donor car had a left side light & wing meeting with another car! It arrived this morning and really is as advertised, but i noticed that at the inner (pointy) end there is a gap between the front & rear housing that looks wider that it should be,
It's hard to see in the photo's, as it's black against black but you can see the gap ringed in red in the photo's. Circled in yellow is what looks like the clip and slot to hold the 2 parts in place, but it looks like the end of the clip is missing ir intentionally cut off; I looked at photos from ebay and other places and although none of them show this area in detail, it does look to me like that clip is cut off in all of them - I can't see if there's a gap though.
Thee are also 2 screws that hold the 2 parts together either side of the slot, they seem untouched and the sealant looks as if it's OK in the gap but again its hard to tell. So my question is that if you have a headlight to hand, or photo's or just by memory, is this gap 'normal'? My guess is that it could be a manufacturing fudge, that the mouldings don't fit perfectly but the sealant and the screws hold it together in the right place.
I can't get the bumper off on my own and have no help so before I take it to my local crash repairer to change it, I want to be reasonably sure this is OK as I do have time to return it if not.
Many thanks in advance :)
Attachments​
The beams are flat topped, but they are handed. The flat top just means the step up to the left has a flat top rather than the older style angled up.
I think a LHD unit in the UK would be an MOT fail, I guess it will be the same in Ireland.
Apparently the LED units have a flat beam, so there is no LHD/RHD version, they're all the same. Based on what someone else has said on here somewhere though, so IDK for sure.
You are correct, flat beams so LHD and RHD makes no difference. No need for beam deflectors if you go to Europe.
No, it’s the same part number for the headlights whether for a LHD or RHD market.
The beams aren’t supposed to be ‘stepped’ but it seems that in the UK they’re delivered like that. It’s not done anywhere else so far as I know and if it is, it’s just a tweak on the adjustment screws
The low beam seems to consist of two LEDs, I suspect they can be individually aligned within the lamp unit? In the UK certainly the beam pattern is not flat but stepped - there is a lengthy thread on this somewhere!
There is no individual adjustment for the LEDs inside the headlight. You can adjust high and low beam on each side, independently. I repeat….the part numbers for each headlight are the same for the trophy (UK) or the Luxury (EU) versions.
Thread here for the adjustments MG4 Trophy headlamp adjustment
And you linked to my post about the adjusters!
Look at the photos in that thread, the beam is stepped not flat.
So as you lot hijacked my original post/question, I did some research in both teh UK MOT manual and the Irish NCT manual.
THe answer is simply that in effect, there is NO 'kick-up' on the MG4 headlights, that bit of a slope is probably due to a slight misalignment when fitted. The slightly raised bit oin the middle of the beam isn't significant.
In the MOT manual, these are flat beams - period!
4.1.2. Headlamp alignment​
You must inspect all dipped beam headlamps fitted.
The type of headlamp will determine whether the aim must be checked on dipped or main beam (see Diagrams 1, 2 and 3).
A flat top or other alternative headlamp dipped beam pattern is acceptable as long as all of the beam upper edge, including any ‘peak’ is contained within the appropriate tolerance band.
The full section is here and as you will see, these are neither European type (although they may have a European approval mark - so nothing to say they can't be fitted in your car); nor are they British American type headlamps (from the NCT manual, "The lens of this type of headlamp is circular and likely to be of the sealed beam construction")
So in each case (UK or Ireland/EU) the beam patterns just have to be within the bands on the relevant charts and more info is further in to section 4.1.2 (my underlinie and bolding):
European type - check on dipped beam​
European type lamps have one of the following:
  • an asymmetric dipped beam pattern with
    • a horizontal cut-off on the right
    • a wedge of light above the horizontal towards the left, known as the ‘kick up’
  • lens may have European approval mark
For European type lamp to pass, you must make sure that:
  • beam image ‘kick up’ is visible on the screen, unless it has been masked or it has a flat top beam pattern
  • for headlamps with centres at 850mm or less from the ground, the beam image horizontal cut-off is between the 0.5% and 2.75% horizontal lines
  • for headlamps with centres more than 850mm from the ground, the beam image horizontal cut-off is between the 1.25% and 2.75% horizontal lines
  • white light does not show in the zone formed by the 0% vertical and 0.5% horizontal line
SOOOOOO .... if you want an interpretation on documents like this, ask a Compliance Engineer lol!(Honestly there is so much misleading info about with good intent it s hard to get the correct answer to a lot of things. Use a bit of chalk and mark up a wall or fence (your own or with permission! ) for those cutoff bands and check that way - havinf a slope on the beam is irelevant. Worth mentioning that there are additional requiremtns fo the high bem too but if you wnat me to interpret that I'll do it after work)
PS: I checked again last night the part numbers on the Trophy headlights are the same for UK, EU etc. 1 amp fits all!
...that bit of a slope is probably due to a slight misalignment when fitted.
Weird how my (and others in the UK who have posted images of their patterns) are all "misaligned" exactly the same with a raised area on the left 🤷‍♂️
You keep saying they are flat topped, so do you have a photo of your dipped beam pattern from a single lamp (a single lamp is easier to see rather than two overlapping patterns) showing it is flat?
I have yet to see anyone claiming they are flat to post a real photo to show it, all the photos I have seen so far from the UK have been the same with step.
My old S2000 with HID lamps is "flat" in that the beam pattern on the left does not slope like it used to in the old days, but it has the same step as my MG - it has a metal mask to create it that you can swap for a LHD version.
I agree though that so long as the step up (even if it was on the right) is below the MOT limit of 0.5% it is legal - if less than ideal.
I don’t keep saying the beams are flat - I said they are effectively flat according to the MOT manual and there isn’t really any ‘step’ in the MG4 headlights. The slanted beam isn’t a kick up, neither is i5 a step and it’s so shallow I doubt if it would prevent any dazzling to oncoming traffic!
The bit in the centre is considered to be a peak, not a step and is covered above…
I will take some photos when I a, able to, but I have no suitable walls anywhere near me and storm Amy isn’t letting me out at the moment!
Hi, also looking for a right headlight for a trophy / luxury, EU version 2024
My VIN LSJWH4094RNxxxxxx
I have seen two differences visually while looking for the part:
  1. one includes the thee rectangular led beams
  2. the other (older) has a part of the light sectioned off like an old headlight
I have read in this forum about a third variant, that has integrated turn signalling?
Also in this thread particularly, I read about differences between LHD/RHD? if they are not "flat-top".
The local dealership wants 1100 euros!!! seriously?
I see it sold for 350+ (less than 150 in China plus shipping)
Anyone have a part number? I believe for the right it's OEM 10976804
Any good sources in EU? I'm located in Greece.
Suggestions are very welcome
Hi, only just saw this! the correct art number for the r/h side headlight is 11505843. Not sure what the 10976804 is, might be for the SE version, which is a different type.
Look on this forum for the guidance on changing the headlight - there's a video showing how not to do it(!) and the service doc's for doing it right :)
    Votes: 1,071 77.8%
    Votes: 207 15.0%
    Votes: 100 7.3%
