Undoing the screws securing the frunk liner mouldingI must have missed what the flat blade screwdriver is for. How big does the blade have to be?
Not particularly big, not particularly small.I must have missed what the flat blade screwdriver is for. How big does the blade have to be?
I think I would call this a re-boot rather than a factory reset which although I have not done one I imagine may be more severe and is done from the infotainment system.Interested in how often resets are being done?
You are looking for wide but thin.How big does the blade have to be?
Your Zappi is a 7kw fast charger. You probably mean you haven't used a Rapid charger.Hi
I have never had to do the "10mm spanner reset trick" butI keep one in the glove box just in case .
Also for the record the car has never used any fast charger. I have only used my Zappi charger and the MG granny charger lead . Had car about 10 months.
It would be interesting to understand the charging history of any cars that have had to be reset using the 10mm spanner ?
Happy Easter Everyone
Why do you think we all need quick release when there are not any people who have done this I thought it was a popular fix but it's not by the look of it.I think we all need to fit a quick release isolator to the battery, seems like it will save hassle in the event of need. Has anyone found one that will fit with having to cut anything. I'm looking at this one but can't work out if it'll fit.
6v 12v 24v Heavy Duty Battery Disconnect Cut Off Isolator Switch | eBay UK
Simply Remove or Loosen Wheel To Disconnect Power. BATTERY QUICK DISCONNECT CUT OFF SWITCH. FITS ALL 6V, 12V & 24V BATTERIES. Simply Bolt On Fitting.www.ebay.co.uk
Hi Jomarkh... I have an MG 5LR....what frunk??But I do have a 10mm spanner and flat blade screwdriver ready in the frunk?
Do you fit them?Hi Jomarkh... I have an MG 5LR....what frunk??
