- Jun 13, 2022
- Paignton, UK
- MG4 (2022-2025)
Thanks Gary, I wasn't having a go at you, just trying to get it clear. Totally agree with the above.
Unfortunately that would have to be a specific deviation from the Consumer Rights Act 2015 ... as it as, ANY purchase is covered by the Act, and any enforcement action would be against the Seller. A Manufacturer warranty is over and above your consumer rights, and this can have any reasonable conditions the manufacturer sees fit. (Buying a car from a dealer is no different, per the Act, than buying a washing machine from Currys, for example).It is definitely time government changed the rules so dealers can't hide behind the manufacturer: the dealer should be liable for addressing warranty items regardless of whether the manufacturer plays ball - this separation of businesses should be invisible to the consumer.
Yes, it requires new legislation. That, in fact, is my whole point. We should have that legislation.Unfortunately that would have to be a specific deviation from the Consumer Rights Act 2015 ... as it as, ANY purchase is covered by the Act, and any enforcement action would be against the Seller. A Manufacturer warranty is over and above your consumer rights, and this can have any reasonable conditions the manufacturer sees fit. (Buying a car from a dealer is no different, per the Act, than buying a washing machine from Currys, for example).
That is also why we need new legislation.Yes, the warranty terms form part of the contract, but you can only enforce those terms against the manufacturer not the seller. The difference with a car is that pursuing the manufacturer directly can be more difficult.
Let me me explain this as clearly as I can ! without bringing the integrity of anyone on this forum into question.It is black and white on the document I provided above on page 3: Bushings, 36 months and 48,000 miles.
Lots of heavy powerful cars out there without suspension parts giving up the ghost at 3 years, it's poor the dealer is even debating.Heavier cars and cars with massive power can wear their suspensions much faster - that is a thing - but doesn't apply to the car I have, which is neither particularly heavy nor high performance and certainly hasn't been driven in any way out of the ordinary.
Any experiences on this one? ChatGPT is telling me that changing bushings can be a lot of hassle, so many places charge as much for that as replacing the whole arm. Is it right?In case I need a backup plan... does anyone know if the typical independent garage (eg an ATS) will press bushings into an existing lower arm that is not corroded?
It is £30 for a pair of bushings online and over £500 for my MG dealer to replace both lower arms including new bushings (which is all MG will do - won't replace the bushings without new arms).
I'm afraid I can't allow you to blame the manufacturer.... you have to honour the warranty that comes with the tools you use...... oh.... oops... been thinking too hard today! Totally understandable!Let me me explain this as clearly as I can ! without bringing the integrity of anyone on this forum into question.
Its Microsofts fault : it only downloaded page 1 .... ooops .
Yes, sadly.Lots of heavy powerful cars out there without suspension parts giving up the ghost at 3 years, it's poor the dealer is even debating.
Speaks more to the hassle of MG authorising warranty repairs unfortunately
It is my understanding that this is because when it is often needed the lower arms are rusted as are the bolts. Mine aren't and they are in excellent condition - so it is my belief that this can be done fairly easily.Changing bushings on components such as lower arms costs almost as much as a new lower arm. When I had a 911 turbo, this was also an issue and my independent said exactly that. Just get a new arm. Most of the cost will be the labour anyway, removing and refitting and possibly realignment.
I am even thinking I might be able to do this myself with access to the right equipment - or impose on a friend who has.
Alignment isn't an issue as I need two new front tyres anyway and so I'll get that done afterwards and have it all set up by the tyre place.
