Fogey
- Oct 19, 2022
- Location
- Southampton, England
- Not an MG
Thankyou so much for that, Nigel - excellent and valuable info for any prospective buyer.Ok, did a couple more test runs today using the same route which produced 3.8ml/kw with regen 1 and 3 at 60 tp 65mph.
There was quite a stiff wind which gave some interesting results when comparing driving with the tailwind v against the headwind.
Test 1: Eco mode, regen 3, target speed 65 to 70mph. Average trip speed 63mph. Over 54 miles the ml/kwh was 3.3, which was quite a drop from the 3.8 achieved at just 5mph less.
Over 27 miles with a 20mph tailwind I achieved 3.9. The return 27 miles into the wind gave only 2.7
Test 2: Eco mode, regen 3, target speed 55-60mph.Average trip speed 52mph. Over 54 miles the ml/kwh was 4.5
Over 27 miles with tailwind I achieved 5.0. The return leg into the wind gave 4.0
It's clear that speed and wind conditions have an outsized impact on efficiency. Perhaps the mg4 isn't the most aerodynamic car around, and the wind noise probably is a symptom of that.
Over the tests we have:
55-60mph: 4.5
60-65mph: 3.8
65-70mph: 3.3
20mph tailwind can add 0.5 to 0.6, 20mph headwind can take away 0.5 to 0.6 depending on driving speed. Clearly wind effect can be much higher, today was only around 20mph average wind.
In a way, the results shouldn't be that surprising, as aerodynamic resistance increases with velocity cubed. Plus unlike an ICE-powered car, the EV's energy efficiency is relatively independent of power setting - the ICE "flatters" high-speed operation because of its gross inefficiency at lower power settings.
But I would imagine the MG4 is pretty aerodynamic - it certainly looks it, and underneath it's pretty smooth. Maybe its battery monitoring is a bit pessimistic?
