My iSMART app
pauljohnson
Stockton-on-Tees
My iSmart app shows tyres as normal. However see photograph with no air in tyres
The observation was that the app is showing 0 bar pressure for all 4 tyres, yet the app is also saying that the tyres are Normal. ;)
Always seems to be some discrepancy between app and car, be it tyre pressures, battery %, available range, or temperature readings.
Sometimes the app doesn't register the actual pressures and simply reports the state with no pressures. I've seen mine say all tyres are at zero, while correctly identifying the one that was under pressure and saying the others were normal.
Assuming that the physical tire pressure is actual within limits, this constitutes a timeout in communication (as siteguru corrected my previous misread ?)
Fortunately it seems that the app runs on 2 communication channels, one for readings and one for alerts. Given my misread, it's easier to interpret 0.0 as as intermediate problem. I hope and guess that a refresh showed more believable values
My car says 2.6 on the front and 2.9 (now adjusted) on the rear, however my digital tyre pressure gauge (Topeak D2 I use for my bikes) says 2.2 and 2.5!?
I've adjusted the rear to match the front as thats closer to what it should be
We continually get warnings (both on screen with voice, and on app) that our rear tyres have low pressure, despite them having 2.6 bar each (both the car screen and the app also report 2.6bar each). This is driving us to drink (though not while we drive).
I have noticed that I get reports of low tyre pressure if the rear tyres are not at 2.8 bar (full load). When I set them at 2.5 bar (half load) the car and the app objected. [Ref Owners Manual Page 324].
I have mine set at 2.6 bar all round and have no low pressure warnings.
When charging mine shows zero tyre pressures and also no internal temperature. Only when charging and not always. Works normally once charge has finished.
Thanks, have added a bit more air and (so far) no pesky alerts.
    Votes: 993 77.7%
    Votes: 189 14.8%
    Votes: 96 7.5%
