wattmatters
- Sep 29, 2023
- Hungry Head, NSW Australia
- MG4 (2022-2025)
Range estimate variability. Thought I'd post some actual data to show how much it can vary (and why).
The chart below shows the Normalised Range Estimate calculated at various times over the past four months:
Normalised Range Estimate is the range estimate if the car at the time had 100% state of charge (SOC).
e.g., if for instance the car reported it had an estimated range of 255 km and the SOC was at 66%, then that's 255km / 66%SOC = 3.79 km per %SOC. Multiply by 100 to give a normalised range estimate at 100% SOC, i.e. 379 km.
This is a calculation based on the data the Home Assistant SAIC integration automatically collects from our car. Data collection began in late March this year, so just over four months of data.
We can see normalised range estimate varies quite a bit, and for our car over the last four months between a minimum of 304 km to a maximum of 548 km.
This is for our MG4 Essence, 64 kWh battery. Northern NSW, Australia.
The estimated range the car reports is based on what the car's energy consumption rate has been recently, and that will vary depending on environmental conditions (cold weather reduces range), speed of travel (higher speed reduces range), type of terrain (gaining elevation reduces range), tyre pressures and rolling resistance of different road surfaces, way the car is driven (lot of hard accelerations reduces range), what accessories are being used (e.g. using aircon or heater reduces range) and so on.
In our case the lower range estimates would be associated with periods of highway driving, or including trips up the local mountain (~1km elevation gain). Higher range estimates when doing slower local driving, or include trips down the mountain. Being in rural/regional Australia there is a fair chunk of highway driving in the mix. Each trip to regional centre involves time on a 110 km/h highway, typically using cruise control.
Anyway, this is nothing new to most of you but thought it was novel to normalise the data and display it over a longer time period. It could equally have been an economy rate calculation.
