Not Great Economy
Cartoman
southampton
Hi
Had the S5 for around 3 months now after replacing ZS EV. Enjoying the car but the economy is worse than the ZS by a margin. Getting 2.8 miles/kWh. Mainly short journeys and charged to 100 per cent once since I had the car otherwise charge to 80 per cent. Any ideas on how to improve economy?
Thanks in advance
That's really poor, what is your driving style/environment like? Settings on the car? You've been a ZS driver so you know how the cold works on range.
My own S5 is much better but I don't generally do motorway speeds so..
Had the car since October and its mostly been cold.
I do Normal mode
Local roads - one pedal drive and energy saving on - gives me 3 to 3.6. If its cold and a short journey we get 2 to 3... I think heating the car up on a short journey is a killer.
Motorway doing steady 70 mph - one pedal drive off and energy saving off - gives me around 3.6
What sort of driving / settings are you using
My figures for my MG 4 Trophy LR for Nov and Dec have both been 3.5mls/kWh.
Short journeys at this time of year will certainly be far less efficient, as the heater will be on for the whole journey. Mine on the "since last charge" tab on the trip computer barely gets over 2.3 on these short journeys of a couple of miles each way.
Longer journeys, and my monthly readings are far better however at 3.5mls/kWh. Resetting the trip "accumulated total" changes the predicted milage on the GOM too, last time it increased it from 186 to 215 miles.
I leave mine in eco, closest in the MGS 5 would be comfort, keep the temperature at 22 degrees and use the heated seats (Trophy only) when really cold.
@5teep, is correct in bringing up driving style and environment, but as you (@Cartoman) are not new to EV's then are aware of the range drop during winter.
Intelligent battery heating consumes a lot of energy if its left on. This is only really needed for DC high power charging, or peak discharge when demanding lots of power from the battery when driving hard.
My average is 3.0 often falls to 2.9. Can't even remember last time I got above 3.0.
I'm 58 years old and generally drive steadily. Never understand how people get so much more.
I have owned both Gen1 and Gen 2 models of the ZS EV before going for the S5.
We bought the car right at the end of August, so the weather was pretty mild ( ish ).
I did find back then, that the S5 appeared to be wanting charging less frequently than our previous ZS EV Gen2 did.
Of course now the weather has turned much colder, it’s a different story of course.
We like the cabin space to feel both comfortable, welcoming and a warm space.
We have the climate control set to 24 and we do use the heated seats 💺 first thing, when it is really cold.
They are an absolutely brilliant and very welcomed in the winter.
Does the range get a bashing as a result ?.
Yes absolutely it does, but I really don’t care tbh.
Sorry, but I am not willing to compromise any comforts, in exchange for the extra range it returns, but to be cold when driving.
I will just charge more often if necessary.
Many people make the mistake of, when selecting an EV - they base their chose on a summer time usage pattern, or wild WLTP figures.
This never worked on ICE cars, when it came to MPG estimates, so why should EV’s be any different ?.
Select an EV that will satisfy your winter usage pattern with ease.
Then in the summer, you will think the GOM is never reducing 🤣.
EV cabin heaters are generally extremely good, at eating up the range real fast.
They pull a lot of juice, I think it’s almost 7 kw’s !.
Sorry, back to the question:-
Does the S5 eat up the range faster than the ZS EV did ?.
Honest answer, I really don’t see it being any better, or worse than the S5 in winter conditions tbh.
Would I go back to my ZS if it was slightly more efficient in the colder weather ?.
Short answer - NO !,
I drive very economically most of the time, and average 4.8-5.3 doing that. The worst I have got was on an emergency fast drive at 75 on a cold day with all the heating on, and that returned 2.8.
Hi
Had the S5 for around 3 months now after replacing ZS EV. Enjoying the car but the economy is worse than the ZS by a margin. Getting 2.8 km. Mainly short journeys and charged to 100 per cent once since I had the car otherwise charge to 80 per cent. Any ideas on how to improve economy?
Thanks in advance
I'm getting similar economy figures and like you it's mainly short journeys but I keep the AC/heating on set at 21C and often preheat the cabin via the app and drive in Standard mode.
If I do a longer journey the economy increases to 3.5+ m/kWh in this weather. The difference being I'm not braking and accelerating as often and I'm not heating the car from scratch as frequently for the miles covered.
I do charge at home so even at 2m/kWh it's only costing me 3.5p/mile which is acceptable for driving how I want in the warm.
To put it in perspective a 100 mile journey at 2m/kWh charging cost 7.5p/kWh is £3.75 the same journey at 3.5m/kWh is £2.14 a difference of £1.61
I've found the S5 to be pretty good on economy and certainly better than my old MG5. This is the worst time of the year of course and a low 3.x average would be entirely normal so perhaps you aren't that far off, particularly if your driving is dominated by short journeys.
i have to say im very impressed with the efficiency.
We have a 5 and S5 and the S5 is like for like much better efficiency.
i'm getting 4-4.5 at the moment in the cold which i think is decent, the MG5 is getting 3-3.5ish
i have to say i dont have the Air con on all the time (dont see the need) (never had it on all the time on the 5 either), i use it to defrost / preheat and or as needed, but i dont just leave it on as im sure it uses a lot of energy.
(i do leave the fan/heating on set to 19, fan speed about level 3or 4 which works well for me, just no AC)
Take a look at your Energy Consumption Distribution graph.
We had a good short trip today, giving 4m/kWh and graph looks like this:
Some other trips show less than 65% powering the motor & a lot more for Climate & Other.
Now that is a screen I need to find!!
I do Normal mode
Hi have car set to normal mode and regen to 3. Temp is set to 22c and a/c is on auto. My average speed is showing as 20 mph at present and at present short sharp journeys.
If it helps, I get about 2.8mls per kW when doing school runs on cold mornings sometimes even lower, in the warmer months (but I only really had one of those) it was about 3.2.
I was disappointed but I did tests to weed out what was doing it. Combination of cold and PCT heater. Seriously the PCT PULLS when bringing the cabin from the depths! I've started leaving the car in the garage and that staves off the minus temps (probably better for the battery too!) and now it doesn't have to work so hard to pull the cabin up.
On longer runs like just this weekend, 70 odd miles still cold conditions, heavy oncoming wind most of the journey, it rounds out, to the point I am seriously impressed 4.1! (Cabin set 21c/22c at times, seat heaters intermittently)
It's the nature of small journeys, I even tested it to double check, I got wrapped up and did not use any heating, I get about 3.2 - so stepping up from the mid and high 2's. It's still cheaper than petrol running at 6.5p per kWh and what you don't see with ICE is just how inefficient the engine really is, seriously a cold petrol or diesel engine is not anywhere near 'efficient', the only reason the cabin heats up is literally wasted energy (arguably not wasted in the cold of course) 😆 even then it's delayed, I'd be lucky to get warm by time the school run was over so yeah -wasted 😂
Now I'm toasty all the way, how and when I want it, but it does show up on the dashboard numbers 🤷 🤣
Thanks for your info. Will look for improvement March onwards.
I do Normal mode
Last couple of days spent driving grandkids to and from school. Often sat parked up for 15 mins a day waiting for them with the heater on 20 degrees. Gauge seems stuck at 2m/kwh, but never falls below. I wonder if 2m/kwh is as low as it goes. Has anyone registered less than 2?
