I think you are correct in that the DC charge protocol is 'coarser' than AC with the full control by the BMS.So I would argue that with DC charging, the BMS really has full control. If it wanted to, I suspect that you could do balancing with DC charging, but of course that would be a terrible waste of public charging resource. I suspect that's the only reason that balancing doesn't happen on DC charging: that it's unthinkable, not that it's not possible.
Am very glad someone has wrote down what I was saying in earlier pieceI have ordered the MG ZS 2022 model because it has the new LFP battery chemistry which does not suffer from repeatedly charging to 100%.
The LR does not not suffer adversely from charging to an indicated 100%.Am very glad someone has wrote down what I was saying in earlier piece
What makes you say that? High voltage and high temperature are bad for any battery.The LR does not not suffer adversely from charging to an indicated 100%.
Less weight means slightly better efficiency.Cannot perceive of an advantage of having a smaller battery,
Also if the smaller battery is LFP chemistry, then it is expected to last about 3x as long as NMC etc.
However a smaller capacity battery will experience higher C rates for the same loads, which will tend to slightly reduce the expected life.
Overall, if you need the range, a larger battery is fine. And it's possible that LFP will catch up in energy density in a year or two.
This is for Micheal Hunt because of the chemistry in LFP battery’s you can charge them up to 100% as and when you want to no ifs no butsWhat makes you say that? High voltage and high temperature are bad for any battery.
I'd love to know where this myth comes from.this is not possible in the LFP battery due to it NEEDING to be charged to 100%.
Granted, MG makes it harder to charge the LFP battery to 80%, but it's no harder than with the Mk 1. I really think that MG made a mistake not allowing the LFP battery to be charged to less than 100%, especially since all the logic is there, they just need to not disable it! ?
So Tesla recommends that you leave the charge limit at 100%, but still gives you the option of leaving it lower. And they recommend charging to 100% once a week, a fair bit more often than the once a month recommended by MG.
But I don't see how this translates to "LFP must be charged to 100% every charge". Though I can't quickly find that statement now, perhaps I'm misremembering.
Some say it's the flat voltage Curve that's the problem with LFP the guess o meter has no idea of range left as same voltage at 30% to 80% this is why sort range owners say I parked up with 50% battery and came back after work/shopping iand car now says 30% the truth is unless charged to 100% the bms has no idea of state of charge only if full or almost empty so this it's the reason to charge to 100% for more accurate range View attachment 9878
I have done a number of YouTube videos on my Aussie EV Channel (Electric Car Australia) related to charging our ZS EV. Check these out they might help. Short answer though generally run battery between 20-80% in normal around town use and you wont have any probs.Hi Does anybody have any thought on the best way to charge my MG Zs? I don’t want to over charge it and ruin the battery life. Thing like is it ok to charge it up to 100% every time? How low should I leave it before I charge again? Or is this all a bit trail and error. Thank in advance from a first timer EV
