Parasitic drain on 12V battery
Eventually MG CS will “join up the dots” and realise that they DO have an issue with a batch of T box components in these cars.
Unfortunately for us owners and the dealers, they follow down the same laborious and time consuming route for all parties.
Making numerous appointments to finally conclude with the same diagnosis of the patient.
Until somebody at the mothership decides.
“Hey…… I had one of those issues only last week and the T box was the problem” 🤷🏻.
Until the penny drops - get a booster pack !.
It is stupid that like you people are having to consider boosters to get running again.
Not stupid, in my opinion, just careful!
I bought my Battery Booster when I owned my previous MG5, and never needed it! Now, having needed it at least four times with my S5 I'm only too pleased to have it available.
About to exchange my MG4 for a S5. I have always had a 12V Boost pack in the MG4, never had to use it. However sounds a lot on here with S5 have problems. Early days with MG4 it was common that the 12V terminals were slack after transit.
What is a T-Box????
T-Box = Telematics Box.
Thank you and quick AI googles gives me this. Understand now.
In electric vehicles (EVs), a Telematics Box (or T-Box) is an automotive onboard unit that manages two-way communication between the car and external systems. While standard in many modern vehicles, it performs critical EV-specific functions related to battery management and connectivity.
Core Functions for Electric Cars
  • Battery Health Monitoring: Tracks real-time data such as state of charge (SoC), discharge rates, battery temperature, and voltage.
  • Range Management: Calculates remaining range by combining battery data with external factors like traffic, elevation, and weather.
  • Charging Logistics: Helps drivers find available charging stations and allows fleet managers to schedule charging during off-peak hours to save costs.
  • Remote Control: Enables "connected car" features through smartphone apps, such as remotely starting climate control (pre-conditioning) or locking doors.
  • Emergency & Security: Automatically triggers emergency calls (eCall) during accidents and acts as a GPS tracker if the vehicle is stolen.
Does the USB next to rear-view mirror stay active when car is locked and shutdown?
Is it safe to fit a dashcam to this supply?
I only want dashcam on while I'm in the car.
Thanks
Thanks
I have my dash-cam mounted on the passenger side and the view of the road isn't compromised.
Just be careful where you mount it as it has to be out of the driver's line of sight.
Agreed, but in my case the camera is small enough to fit directly behind the rear-view mirror so is out of sight.
I installed my first dash cam after I had a head-on collision, where I braked and was stationary before the impact, but the oncoming vehicle skidded and hit me. At the scene, he agreed that it was 100% his fault, which he later denied and we went knock-for-knock.
Never again.
(I did write to his employers telling them what a lying, duplicitous toe-rag he was and asked whether they really wanted him in a responsible management position, but I never found out whether that cold revenge paid off.)
Thanks Ian & Clive.
When I fitted ours, the biggest problem (as always) was trying to make a neat job of the cable. With a very short USB cable, I looped it across the 'mirror mounting' to the drivers side. Its mostly obscured by the mirror, so no real reduction in visibility & screen blanks after it turns on, so not a distraction.
Thanks Ian & Clive.
Hi, Back to the 12 volt battery dying.
I have a 2021 MG HS PHEV. everything was fine until the service on the 20th January. Next time I came to drive, the car was dead. MG assist came battery was at 3 volts jumped the car all ok. Was told must be the battery. On charge overnight and next day dead again battery at 3 volts. MG assist suggested the two year old Bosch battery had died (!!). Bought new battery fully charged and fitted. Test drove car after fitting battery charging at 14.1 volts, a bit high I think. When I got home put multi meter onto circuit and something is taking 2.2 amps!!!! with everything turned off.
I hear talk of the T-box and that the EV battery should keep the 12 volt charged. But my car was fine for the last two years so what software update could change this?
