Plastic Wheel Trim
Are there any other plastic wheel trims that fit if we felt like changing them due to breakage cost or look ? Or are we stuck with these at £56 a pop which could turn out to be a bloody expensive cost to just putting some air in your tyres !!!
I am not aware if there are any third party wheel trims that will do the job ?.
I guess leaving them off altogether is one option, if they are in a poor condition due to damage etc ?.
Just to say that although checking my tyre pressures could be easier with the wheel covers removed, I have managed to perform tyre pressure function checks successfully without the need to remove the OEM wheel covers from the rims.
In the case of a puncture, this is a different mater altogether of course.
This is were the plastic covered / protected lever will step up to the plate !.
Ok well it’s good to know that you can get to the dust caps off to check or put some air into the tyres without the need to remove the plastic wheel covers. I didn’t think there were any after market wheel trims but there are some very knowledgeable people on this forum and it doesn’t hurt to ask .
The valve stems are very short, so access is a bit tight, but it is possible.
Removing the trims makes it easier of course, but then you run the risk of cracking them if your not careful ?.
A set of plastic, standard length trim removal tools, is just not going to be long enough to assist with the removal of these aero covers unfortunately.
Using a long pry bar that has the shank / blade covered by protective film, does appear to be a favoured option by some.
This offers the opportunity to slide the pry bar behind the trim and start the process of levering back on the retaining tabs, that can be unwilling to initially “let go” of its grip on the spokes of the alloy rim behind.
Focussing on one small section of the trim first and then pulling back hard with your hands, can result in the trim cracking / splitting.
Other people have said they had no problem in removing these trims.
It has been suggested that by using both hands simultaneously and then by pulling with equal force, they should release without causing damage by splitting / cracking.
Pulling back on the wheel cover in a single location, appears to be the incorrect approach.
Thanks @Lovemyev seems your the only one who replies on this forum ?? I was hoping somebody had found the perfect tool that I could buy but never mind I’m sure I’ll rind something one tip is when you get the covers off put some wax on them so next time there not so difficult to remove.
One of the wheel cover slots is larger than the others & is made for the air valve access; just remove & rotate to sit that over the valves. See below, is very clear, the bottom most slot & marked with green texta.
  • Has anyone found the perfect tool to remove these covers ? Or is it a case of trial and error with a set of trim removal tools.
As per my earlier post & photo the hubs need to be rotated so as to correclty use the larger slot for air valve access (clearly these are not usually fitted correctly at shipment). Re. removing the covers:
My son (an experienced car mechanic) had a look at this for a few seconds, then immediatley and easily removed the covers so as to rotate for the air valve access:
  • Instert fingers as close as possible to the CENTRE of the hub through the slots, then pull.
  • Centre location is the trick & gives maximum leverage; try to do this from the outside of the hubs & yes, will bend & make you feel you are going to break it.
  • Get it right once & will be no problem doing it again, but then if the hubs are rotated to the correct position, this will hardly be necessary again (unless damaged or broken etc).
BTW, I much prefer these plastic removable hubs than the alloys I had on my earlier gen 1 ZS EV; those could be damaged if parked badly etc & cost a bomb to replace; these detachable hubs, no such problem. They're also meant to be slightly better in terms of aerodynamics & overall energy efficiency.
There is also an embossed image of a valve next to the larger slot.
