Probably won’t get an MG4 again
Thanks for this balanced view. We did a test drive and loved it, but we are currently driving a mk1 skoda fabia! I'm also getting creaky so could do with something easier to ebter/exit, and something with a bigger boot. Our budget is 15k. This is seven times more than we've paid for any other car in about 40 years, and most of our other cars have far exceeded 100k miles. We actually sold on our old VW passat tdi with 300k on the clock! For 15k there are loads of great ICE cars that would fit the bill, and which I could get serviced /repaired by my trusted local mechanic.
However, all that having been said, I'm keen to jump on the EV bandwagon for some, possibly irrational, reason. It seems my choice of EV for 15k is between an older and higher mileage early model (eg BMW i3) or a much newer, low mileage model with lots of warranty, like the MG4. My heart says go for it, but having read all the niggles, my head says don't! I expect I'll go with my heart and hope for the best.
You can pick up MK2 Hyundai Kona 64 premiums for that money, not a startling car by any means but solid and very efficient.
I would definitely be going down the ev route whatever you choose
We have also always bought older cars for around £3k and run them until something leads us to get rid off (write-off, free car from a relative).
We were too. Many people are.
Being part of the energy transition is a big thing for me. Pebbles prefers the way they drive. For others it is wanting the superior tech. For others still (the XPower owners on here) it will be the acceleration.
Second hand EVs are getting much more affordable.
Kias, Hyundais and Stellantis cars available for reasonable prices, along with the MGs (which are often the best bang for buck).
I guess with any second hand car you might get a lemon, but at least with an EV you won't have a dodgy engine to worry about.
Won't high mileage electric motors have wear and tear issues?
All the AI search engines say you will get 10- 15 years and up to 200,000 miles from an EV motor. So a longer life than an ICE motor, considering that is with zero servicing, it seems pretty cost effective.
And there's no wear & tear from running cold engines, warming up etc which affect piston engines every time they are used, dust ingestion through air filters etc.
All spinning high torque motors will suffer wear and tear problems if used long enough. Quite a few Nissan Leafs suffer bearing wear which need replacing, and some Teslas have coolant seal failures in the motor leading to failure, both electrical and bearing corrosion. The quality, fitment and design of the parts contributes to their demise. There are some high mileage MGs out there with no ill effects,) but still early days for the newer models.
That's also a very low end estimate. There is virtually no wear and tear at all on a modern EV motor. The only eventual point of failure should be the shaft bearings. Similar motors used in industry have run times before failure comparable to millions of miles driven.
Industrial motors tend to be a heavier construction and run for longer periods at a constant velocity without the acceleration / deceleration and changing torque curves that EV motors are subjected to. A similar comparison could be the bearing arrangement in an alternator in an ICE car, although these are not subjected to the same "rev " range. These tend to be usually quite long lived and not particularly looked after , and they only get noticed when they start to fail .
I think some Zoe motors have suffered from a design flaw so they don't necessarily last.
Hopefully the MG ones are well designed and will last a very long time.
If you think of trams or trolleybuses or electric trains (which is the majority as even diesels are electric drive), they have electric motors that last millions of miles. Some won't be much more powerful than the motors on an EV.
My car salary sacrifice car lease is up as I am changing companies. My new company also does car salsac, but I likely won’t be getting an MG4 again. It’s been a nice car, but for me hasn’t quite delivered. It’s was not just the 2 months that the garage had it while they fixed the pretty important ‘not being able to charge issue’. It’s the smaller niggles, such as the charger door freezing open often. No rear seat light meaning we have to use a torch for the kids to clip their seat belts in, especially when is our turn to take other kids to clubs. The 120 mile battery range during the winter. The fact that the temperature setting has little relation to the actual temperature, they should just change it to high/medium/low? Not being able to add a roof rack in the UK. Fighting against the lane keeping on country roads. It misting up far to easily, although I know it does demist using the maximum demist button quick. The amount of mud that sticks to it I will also not miss, much more sticks than the 4 other cars I’ve owned where I live here!
Now it may be that our next car has similar, or differently annoying things! But I think it will be worth finding that out as I’ll be leasing again.
I will miss the smooth quickness and solid handling around the Scottish country lanes where I live. As well as pretty good snow and ice handling (we have all weather tyres on). I will also miss the vehicle to load functionality, so will make sure my next one does that. I will miss the quick cabin heating in the early morning. I will also of course miss the fact that it is a very good EV car for the price considering the price of EVs!
I guess in summary I think this is a good city car, but not so great for me as a country car in the cold and dark days of a Scottish rural winter.
Hope everyone keeps enjoying their MG4’s and safe driving everyone 😊
I agree, I have had the car for two years now, during the summer, love the car, I have no choice but to use the public charging infrastructure, which is expensive and through the winter, I have found that it is very expensive.
I had the privilege of working in the maintenance sheds for Manchesters Metrolink . The electric motors are the size of a medium/large barrel with two on each bogie. They needed the least maintenance of any of the vast amount of parts which make up a tram and were reliable. But were designed to be robust and bulletproof , but with that came weight, which of course was not a concern in a tram. EV motors ideally require lightness and with that there will be compromises both in designs and materials , add in the fact they only need to be expected to last a certain mileage or an amount of years ( at least past the warranty allowance ) as a customer expectation , then that will also be factored into the design and cost package.
I bought my mg4 se long range £29500 in oct 2023 today went to trade it in for the new Renault 5 it’s now worth £12000 the depreciation of the mg4 is awful .
No worse than many others, of that type of car, EV or ICE 🙂👍
Or wonderful, depending on your point of view. A 2 year old car for 41% of it's new cost sounds pretty good to me ;)
Won't all cars cost a lot new and end up worthless?
Cars really aren't a rational purchase are they!
Not all, but most. Exotic marques and those that go on to become classics after several decades hold or can even exceed their original price by many times!
Agreed. In the late 60's and early 70's E Type Jags were going through the auctions with a reserve of £100 each, which is the equivalent of £2000 in today's money.
What is the mileage / does it have fsh?
Is the £12000 what it is worth or what you have been offered p/ex? You may do better selling privately if it is low-mileage & fsh. Also, check to see what discount off the R5 you may be able to negotiate if you don't p/ex. Sounds like there could be some wiggle-room with hard bartering with your dealer - you can always decline their offer and hint you will check out other Renault dealers first. If, however, the R5 is in high demand being new and not much availability you may not be in the best bargaining positing :(
Bargaining power is key.
R5 seems to be popular so there are limited discounts. It is a desirable design with great reviews and limited numbers available in the UK.
The MGS5 was offered at a £9k discount fairly quickly. MG4 has been available with bigger discounts over time.
There are loads of pre-reg'd 2025 MG4 for £17,500 today. That is going to hit used prices.
Same with stellantis EVs - they aren't fashionable so there are massive discounts. The list price is high as well because this gets referenced for accountancy and tax purposes.
I thought of the caveat about classic cars going up in value after time has passed. I didn't add it because it doesn't seem relevant. They aren't making more of them and mass produced cars are unlikely to become classics.
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
