Radio module replacement
Deleted member 9064
Hi guys my long range mg5 went into dealers today as it was showing radio module initialising when they phoned me up they confirmed that it needed a replacementhol module they said they would order the part but could not give me an eta. Does anyone who’s had this done know the waiting time for the part.
It probably just needs DAB files installing
I have them if you need them
Hi trinenmark. I'm waiting for MG to get back to me about the same issue.
Is it okay for you to send me a DM too, to get the files. Thanks
Hi sure do you know how to do it
All up and running again.
I really can’t thank you enough for that. It’s saved me at least two 40 miles round trips to the dealership.
Do you know if it’s the same file for the ZS as I’ve seen a load of similar posts on that side?
Thanks again.
Thanks again.
Yes the DAB file is the same
Good evening, I kindly ask if the files for "radio initialization module" are also good for the Ehs and if so how do you install, thank you very much, have a nice day
Hi, Benutti, i think i have your problem, because i had delated the DAB patch from the car. So, if you share the patch with me, i will try to installa it and then i will write you about my resoults. Thanks in advice
