Thanks, that is very useful and interesting data.I do seem to have approx 42.5 Kw usable capacity, but my car chargers to 455v, and I drove until my car reached 450v, I did 6 miles at 3 miles per kw, so the 5 volts at the top works out about 2kw of energy, which could mean you infact do have 40.5 KW usable capacity, if you've had the latest update (450v) and MG haven't allowed anymore capacity to be used at the bottom end. I can't comment on this though because no one has given information about what voltage readings they're getting at the bottom end.
They aren’t reducing the range we have been told. Just reduced the top end voltage and the bottom end to keep useable battery capacity the same and hence the range the same.Bear in mind aswell, that MG aren't actually doing anything wrong by reducing the voltage and range by approx 5% because the warranty on the car covers for a loss of 30% over 7 years.
I have the latest update and can now charge whilst unlocked. Voltage has dropped from 455v to 449v but my range hasn't changed.
I agree. That was one of the points that I made and asked if MG will be completing the update on all models if it is so important - it seems from posts on here that they are not - if it’s as important to battery pack longevity as is proposed then why not update all cars?Just a bit curious as to why tweak the maximum voltage down to 450v from 455v to improve longevity of the battery pack? Do MG have doubts whether the usable life of the pack will extend throughout the warranty period? If so what happens to those that are still on the BMS version that charges to 455v max and may never be updated? Are they at risk of being warranty replacements say in years 5 or 6? That is sailing very close in specification terms and I would have thought a 10 year+ life expectancy for something that is warranted for 7 years to be more conservative.
You may be right– owners should not have to speculate though! Updates should have clear release notesI have a theory that MG have reduced the voltage on the pack because a number of cars have had the main HV fuse failure.
My local dealer had the fuse fail while carrying out the PDI checks !.
A second car arrived at the dealership on a flat bed with HV fuse failure.
Both cars where shipped out to another dealer about 40 miles away.
Good points. I wonder if reducing the top end voltage also reduces the motor power output? It would wouldn’t it? That would mean the published power has also changed.I do seem to have approx 42.5 Kw usable capacity, but my car chargers to 455v, and I drove until my car reached 450v, I did 6 miles at 3 miles per kw, so the 5 volts at the top works out about 2kw of energy, which could mean you infact do have 40.5 KW usable capacity, if you've had the latest update (450v) and MG haven't allowed anymore capacity to be used at the bottom end. I can't comment on this though because no one has given information about what voltage readings they're getting at the bottom end.
If that is the case then MG should recall all cars and complete the update shouldn’t they? It seems some have had their cars in service recently and not had the update.The reduction in voltage is actually a really good move. Previously the fully charged voltage meant a cell voltage of 4.22v per cell. This is really unhealthy for longevity of this type of lithium cell chemistry. The new figure of 4.16v is much better. I just hope they aren't letting it drop too low to keep the range constant.
It would appear that cars leaving the factory or dealers after the PDI are now having the packs set to 450 volts max now according to the latest info from Miles R.I agree. That was one of the points that I made and asked if MG will be completing the update on all models if it is so important - it seems from posts on here that they are not - if it’s as important to battery pack longevity as is proposed then why not update all cars?
