richlove
- Feb 27, 2023
- Location
- Woburn, Bedfordshire
- MG4
This is probably not MG4 specific, so feel free to move if not appropriate. [Edit: Moved to General Chat.]
I have this new charger (10m extension) that I've been using as I don't have a proper home install (and can't), it plugs in to the 3 pin mains. It has an amp limit setting which I've been using set to 10 amps, which has been giving me 2.5kw from the charger, 2kw seen by the car.
I was interested to see what would happen if I switched it to the 13 amp setting. It seems now I'm getting 3kw at the charger, 2.7kw at the car, drawing 12 amps:
This would get me 5% per hour (vs 4% per hour @ 10 amps), it doesn't sound much, though would be quite helpful during the 00:30-->04:30 Octopus Go cheaper window.
Question is, am I fairly safe to be running this or beginning to push things uncomfortably? I'm tempted to run it a couple of hours and monitor the temperature displayed (it usually goes to about 30 degrees).
