Same plug for charging and or V2L
I want to make a plug which can be used for both charging and V2L But I do not have an MG4 yet.
My question is:
What happens if the V2L plug is removed from the car when V2l is active and the plug is replaced by the normal AC type 2 charger plug ? Is there something one must do inside the car for starting up charging or will it start charging by default. ?
Yes l remove V2L adapter, purchased from eBay, then l found Locking and unlocking inserting charger cable then lock car, it will start charging at desired time
grundig and Philips had a collaboration at the time. I worked at a company dealing with grundig tv equipment back then
Most EU manufacturers used the same electronic parts, made by MBLE in Belgium, that time a leading manufacturer of electronic parts and lamps in the EU. Depending of the country and distribution chains different brands where commercialized. Philips, Grundig, Schaup-Lorenz, Telefunken, enz.. licensed by Philips. Remember the famous 87Y in TV equipment.
I think you'll find VHS 2000 was invented by Grundig.
V2000 is an invention of Philips, VHS by JVC. V2000 video cassettes where produced by Philips and Grundig.
    Votes: 1,023 77.6%
    Votes: 199 15.1%
    Votes: 96 7.3%
