side impact warning light
Only comes on when car at the side of you do not under stand what you try to do.
On my ZS EV Trophy Connect its actually quite bright and also comes on if I'm reversing out of a drive and someone passes. I have even had it warn of a car several houses down, so some distance. Maybe the LED has improved from the HS version but I have found it very visible even in bright sunshine. Perhaps other HS drivers might want to chip in.
The blind spot monitoring warning system, in the ZS EV ( Gen2 ) is complete different in the HS model.
The ZS EV has an orange visible warning light in the glass of the door mirrors, while the warning light system on the HS is only small and is displayed inside of the car via a light on the interior trim of the car.
One owner has carried out a modification to improve this situation on his HS.
It is a very detailed mod with pictures and instructions included.
I will try and find the link to the page.
