Kenp1
Use the parking brake switch to move the car with the seatbelt undone or false alert, I've done it loads of times when moving the car on the drive.
I'd hardly call it a problem but this is how you can reproduce the behaviour.I've never seen the seatbelt issue, is this common? Also you can move the car with the seatbelt undone.
I'm a bit confused, that sounds correct to me.
Definitely not how it should work. You can drive without the seatbelt on and after you get to 10kph ( or something like that) the "bonging" will start until you put it on, albeit it still won't stop you driving.In mine it won't move until you put your belt on, if you use the parking brake switch it will move with the belt off.
I can't move my car without the drivers seat belt engaged. It just refuses to go into gear, forward or reverse.I've never seen the seatbelt issue, is this common? Also you can move the car with the seatbelt undone.
You can certainly drive the car initially without the seatbelt on. The behaviour is subsequent to you driving with it on.
Goodness gracious! That would peeve me no end. Have you asked MG if they can explain it?I can't. I've tried all sorts of things. Sometimes I have to move it on the drive but I have to put the seatbelt on to do it. Just won't go into forward or reverse without it.
Basically same here, I leave it on, it works, sometimes better than me sometimes worse, but never too far away from what I'd normally do.All the anti auto-high-beam commentary ... mine just works pretty much as it should; very few erroneous operations.![]()
Drive it in/out of my garage before loading/unloading?????But really why would you want to drive the car without the seatbelt on?????
Moving the car around in my driveway to make room for my motorbikes/wash car/clean driveway/etcBut really why would you want to drive the car without the seatbelt on?????
OK, just to be safe I've removed my link, I'm sure people can find them for themselves.I wasn't going to get these because the car can be moved with the seatbelt off, but I can't see any safety standards on these.
