Mike01Hu
- Aug 8, 2021
- Axminster, UK
- MG4 (2022-2025)
Solar only makes sense if you also have battery storage with it. If you charge during daylight on a very bright day, the max you will get will be about 90% of your solar panel rating and, depending on your solar inverter, you may still use grid power to cover what your inverter can't deliver. My inverter can deliver 5kW from the panels and storage batteries, but the car uses 7kW so the extra 2kW comes from the grid, so I'd suffer the daytime tariff. I charge overnight where the inverter delivers its maximum from the battery storage and the rest comes from the grid at the nighttime tariff. I have Zappi plus 4kW panels and 18.2kWh of storage. The 18.2 is reduced to about 14kWh to maximise battery life. Smarter systems can use only what the panels and storage can deliver and not use the grid or you could have an off-grid solar system. If you've got a large roof area, you can fit more panels. Remember, the winter months from mid-October to mid-March are poor for solar energy and overnight charging is best; of course, if you have battery storage, you can charge those too and save energy for daytime purposes.Hi again all.
Seems soon we will be able to get a £0.60p per hour saving on our electricity bill when charging the car overnite ( So Energy)
We are likely to do 8,000/10,000 a year maximum.
We have a Zappi 2, 7A charger
Prior to getting the car had considered some minimal solar charging to top up during the day.
Any thoughts on the minimum charge/ solar panels I could use to make it worthwhile, or stick to low eV charge rate
