Solar with battery, loving it!
I have my battery outside as I had no room inside the house to put it. I bought a metal shed, and with a bit of DIY, made the depth shallower so that it would sit nicely around the side of the house. All the battery company said was to make sure there were plenty of vents for cooling.
That looks a great solution, may I ask where you got the shed from please?
The bits about puncturing and nails etc scared me and reminded me of the time I was in the loft of an older house installing a shower. There was a faint smell like gas. No wonder - the gas pipe supplying the. Boiler had been pierced ( with a nail ? )
It had been undisturbed for well over a year until I found it according to the customer. Whoever did it had smeared the pipe and a spent matchstick with silicone sealant and wedged the match in the hole.
( i’m fairly sure he didn’t use the match to identify the source of the damage he’d caused )
Bit off topic but our first house was an old terraced house with gas lead piping and a space underneath the floor of about 3 ft. We had a leak in the gas pipe and called the gas board and we both went under the floor. He found the leak with a lighted match. ♨️
There is a similar old thread here;
Or this one;
It was this thread where johnb80 posted the picture of his outside installation which gave me the idea for the metal shed, so thank you johnb80.
Maybe a moderator would like to move it over. :)
I've moved the derail into the newer of these two threads. There are quite a lot of similar threads in the relevant subforum and I don't want to interfere any further. If anyone thinks a different thread should be used, or that this should be its own thread, let me know.
I started to watch the good professor's video - one of them anyway - and quickly formed the impression that he's an anti-EV scaremongering loon.
I got the dimensions of the battery from the manufacturer's website along with the clearance needed. They haven't done an installation in an external cabinet before so have been monitoring temperature and humidity and have not reported any problems through the summer or winter. :)
I insulated the bottom section of my shed, put heater mats under the batteries and installed temperature controllers to run fans or heaters. In wintertime the heaters have been needed, no problems with overheating.
Where did you get your toolstore cabinet/shed from. Quite attractive.
Amazon
Derail about home batteries moved here.
6.6 kW system in NSW on a sunny day I generate 40+ kWh my car gets the arvo 5 hours per day. Only spent $16 dollars on out side electricity in 4,000 km and no electricity bill in 2years , wish I had a battery hate selling for 7c/kWh to AGL (electricity retailer) .
You can also use this link as well in a slightly different format.
If you study this for a few days you quickly realise:
  • We are still heavily dependent on gas, that's the biggest source of electricity in winter by far (typically 40%).
  • We are still using coal (1 power station left, due to close in September).
  • Around 10% of our power is now imported from connectors to Norway, Denmark, Belgium, France, Netherlands. We also supply Ireland and sometimes export.
  • Nuclear is a really small fraction.
  • I didn't realise we were burning so much biomass, wonder what this is specifically?
  • Solar is disappointing in winter.
  • Wind, when it blows, is great but it doesn't always blow.
  • There's clearly money to be made speculating on the wild price swings throughout each day.
  • We pay an awful lot more than the cost of generation: there's a ton of costs on top.
I’ll bid 8c/kWh for your leftovers if you’ve got a decent extension lead ?.
The biomass is processed wood chips from, would you believe it, Canada, where it is transported across the Atlantic in big, bunker fuel burning cargo ships. Bob Llewellyn did one of his rants on it last year. You couldn't make it up.
On a positive note, the Isle of Wight tidal turbine project seems to be progressing.
We currently have 10 panels which produce around 18 kw a day in summer and 2kw in winter, all this is sold to EDF and we get around 1400 euros annually. We are starting major restorations and are considerating all energy options , u/f heating , solar ,batteries , heat pumps. etc. The major problem we see is that if we size the project for winter usage when we need it most then there will be wasted production in summer as we are already on the maximum level for private selling back to EDF. And again the costs and hassle of installation versus the benefits ,we pay on average 18 cents kwh for day time usage, this will of course rise , but the only way I see of re-couping the outlay costs is if we sell up.
If you burn wood chips faster than the trees can grow....... you can see where this is going?
What’s the old tongue twister ?
How much wood can a wood chipper chip if you burn the chips faster in a power station that’s powering the chippers ??
Yeah it all ends up just as daft as burning oil to carry wood over an ocean to burn …….. if only I had an ice car I could disappear up my own exhaust pipe.
So Drax used waste wood from the logging industry, so not using trees . . .
until that was someone traced that wood back to virgin forests in Canada and logging for wood chips under spurious licencing arrangements!
I've just moved a continuation of the original derail in here too. If this isn't the best place for it, I'm open to suggestions. But I'm fairly sure the best place is not a thread entitled "EV opposition in the media is ramping up."
Would u not pump excess power in to a vehicle as I do 5 hours a day for vehicle, my system at the moment in summer can do over 40 kWh a day .
