- Jun 15, 2024
- Location
- North Yorkshire. XPower.
- MG4
Yes you'd have loved this experience on the side of the B269 wouldn't you.
Well done @TimothyN, I use one of these to locate the wheels, it just screws into one of the bolt holes, the top one is best, then you slip the wheel onto it and slide it into position, it makes the job so much easier.The only difficulty, and it was a big difficulty, was getting the original wheel back on, which is not only a lot heavier, but you can't see the central hub. But that would be done by the garage IRL, so not a problem.
I bought a similar one of these myself and it was a big help !.Well done @TimothyN, I use one of these to locate the wheels, it just screws into one of the bolt holes, the top one is best, then you slip the wheel onto it and slide it into position, it makes the job so much easier.
Not really, it just means you have to a front/rear swap if the puncture is in a front tyre. A stiff chassis meant that the entire side of the car was lifted evenly regardless of whether you jacked at the front or the back so it's just a question of dealing with a few more wheel nuts.
There was no problem at all getting the wheel on the front. I didn't drive with it, but it span freely and was nowhere near the brake.
View attachment 39531View attachment 39532View attachment 39533
I think this is a winner!
And a big thank you to the bullies who made me do this. I would have been f**ked otherwise!
The second realisation was that, as they don't provide a spare wheel, they don't provide a brace. I sort of assumed that the people who provided the wheel and jack would also provide a brace, but the item I had, at a glance, assumed was a brace was only for raising the jack.
So Screwfix for a telescopic brace.
