Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
I mentioned this in another thread but nobody came back to me on it, so I thought I'd start a new thread.
Lots of people (including some MG4 online reviews) have mentioned that you have to crank the temperature way up to get decent heating from the car. Certainly mine is like that. I have however seen one or two people claim that this is not the case with their car.
The temperature range on the system starts at LO and ends at HI, obviously. This part is normal. It's the numbers in between that are peculiar. In my car the first number as you go up from LO is 18C. The last number before you reach HI is 32C.
This is what I think is wrong. In my Golf the last number before you hit HI was 26C, and although I can't remember exactly what the first number up from LO was, I'm damn sure it was less than 18C. Nobody in their right mind wants to heat a car interior up to 32C, never mind more than that, but wanting it chilled down below 18C doesn't seem at all unreasonable.
I think the offset is 5 degrees, because I get the same level of comfort at 28C in my MG4 as I did at 23C in my Golf. Others have guessed the same. I don't see this as a calibration issue, I see it as a labelling issue. It's as if someone had taken the physical dial on my Golf and stuck new numbers over the existing ones, each number five higher than the real one. Obviously we can't relabel the MG4's readout to the correct numbers because it's on a screen and not a physical dial, but I'm convinced this is all it is. What a daft bug!
What I want to know, what is the temperature range available on the system for those people who believe they don't have this issue? Does everyone's range go from 18C to 32C, or are some correctly labelled and show 13C to 27C?
