You are driving your car normally in realistic everyday conditions. With the heating on. EnjoyWhat am I doing wrong?
Is your battery heater definitely off ? That's about the only thing that dragged my average below 3 back in mid winter.I've yet to see better than 3 miles/KW and that was coming down off the Pentlands from Silverburn. What am I doing wrong?
You are driving your car normally in realistic everyday conditions. With the heating on. Enjoy![]()
I think you have an SE LFP too ? I drive mine with practically no thought of efficiency and I really struggle to get lower than 3.5 miles kWh even on short trips.
As soon as the temp gets above 10 degrees and the roads dry out, 4 miles is easily achievable .
Brakes binding ? They'll likely have no factory grease applied to the the sliding components like many owners have found.
If your car is driving ok with good power there's probably nothing to worry about, just seem unusally thirsty.
Just as the m/kwh never displays less than two even if you have managed it, I've never seen the disp go higher than 20. Seems to be the limit of displayed values. Often seeing 20 living on top of a hill.
