Unable to schedule charger
I assume you have tried setting myenergi to “Stop all” and scheduling directly on your Zappi or via whatever app you have via eon?
On the Zappi unit I set it to eco++ and on the app I set it to schedule. I called the Zappi helpline and they confirmed the set up was correct. It appears to be the car stopping the scheduled charge, I have to get into car and press start on the battery info panel then it starts the scheduled charge.
It remains a mystery to me!
Hi, I have had issues with my Easee charger this may help if you too have issues charging.
Before you do anything set the schedule you want on your app I only use “weekly scheduling” if you also have that.
1 Disable any automatic scheduling on the car and set Easee App I use “weekly schedule” setting.
2 Connect cable to wall charger.
3 Start the car to open the flap and connect cable to car before it switches itself off.
4 When I do this, my app now shows it is “waiting for schedule”
5 Should work now😊
All the best
Steve
Hi, this may help. I have had issues with my Easee charger.
Before you do anything set the schedule you want on your app I only use delayed scheduling if you also have that.
2
Start the car to open the flap ready for later.
3
Wait for the car to lock itself and go into sleep mode.
4
Connect charge cable to car then connect charge cable to charger on the wall
5
When I do this, my app now shows it is “waiting for schedule” Should work now.
6
Wait and see if your car starts to charge as requested by your app settings
All the best
Steve
Brilliant! Thanks for the advice, Steve, as I'm still experiencing difficulties 3 weeks in. I will follow your advice above and let you know the outcome, fingers crossed!
Hi
Hi Louddie
I am still learning myself and I am definitely not an expert on this but one thing I noticed last night on the Easee One charger.
If if you use the “delayed start” it will only take effect on the day you are actually in.
So you can set it from say it’s 5 o’clock any time up to 11:55 pm (same day) and it will start to charge but if you set it to say 00:05 five past midnight, that is the next day, and it won’t pick that up as it thinks 00:05 was at the start of the current day.
It can only be set for time ahead of say if it’s 5 o’clock to 11:55 on the same day.
Hope this helps
Steve
    Votes: 1,050 77.8%
    Votes: 204 15.1%
