USB Dashcam on MG5 ev facelift
franoreilly
Dublin
Hey all, new member here, so hello! Will be picking up a new mg5 exclusive in July
I use two Garmin Dash Cam Mini 2 - one front one rear - on my current ICE. They are nice small discreet units, plugged into usb sockets (ie. not hardwired in), which works quite well and the wires are tucked in behind panels etc.
I want to bring these across to the new MG5 if possible
Anyone fit these dashcams or anything related ie usb dashcams in mg5? Any gotchas e.g. battery drain leaving them plugged in? Would I have to go the hardwired route?
Thanks!
Thanks!
There's lots of posts on this forum about fitting dashcams, just do a search.
I've not fitted the Garmin's but installed a Nextbase in my MG5 Trophy. Unfortunately there are no USB's at the interior mirror - unlike the ZS, so you will need to hardwire or run a cable to the front USB's if you don't want a semi-permanent installation.
Thanks!
Fitted one into my MG5 LR recently powered from front power socket. Wires easily hidden behind trim and door seals for rear camera. Rear fixing bracket would not stay stuck to window so wedged bracket between glass and trim (large gap at top) by using diy rubber wedges from a rubber eraser. Holds fine.
