Is this via some sort of special device or just a long extension cord? I would be interested to find out what is required to power the entire house without having extension cords dotted everywhere from that v2l adapter.
I've just checked out the ability to power the whole house in the event of a power cut.  First make sure that you're not going to demand more than 2.2kWh - so keep power-hungry devices such as the washing machine or electric shower turned off.  FYI I have a TN-S supply with RCBOs on each circuit.
Now children, don't try this at home...
Here's a quick-and-dirty method that breaks every rule in the book but it's a simple and effective way to power your house from the car, rather than the other way round:
1) Make a short 'death' lead with 13A plugs at each end and ensure that the earth wire is NOT connected.  This is necessary because the car's earth (on the PE pin) isn't bonded to its neutral (carried on the N pin).  Failure to float the earth will cause the car's residual current protection to halt the discharge process the moment it's connected to the domestic supply - where earth and neutral are bonded locally in the case of a TN-C supply, or at the substation with a TN-S supply.
2)
TURN OFF THE MAIN BREAKER to isolate your consumer unit from the incoming mains supply and ensure you don't try to supply the national grid!
3) Plug one end of your 'death' lead into the V2L's trailing socket(s) and plug the other end of the 'death' lead into the nearest convenient 13A outlet, probably in your garage.
4) Make sure that power-hungry devices such as the washing m/c or electric shower are turned off, then start the car's discharge process.
You may not wish to power the whole house, maybe just the g/f ring main.  If so, only the MCB or RCBO associated with that circuit will need to be turned off.  Your 'death' lead should then be plugged into an appropriate 13A outlet indoors, which will probably require use of an extension lead.  Finally, please don't attempt this if you're not a competent person and make sure no-one other than yourself has access to the 'death' lead.
