What is the difference between the two USB ports on the ZS EV?
I have the car, and i can only get Android Auto to connect using the USB-A plug.
The USB-C plug works for charging.
That's disappointing, the manual implies that they both data and power. It makes me wonder whether it was written that way to deceive.
In the car menu you can select usb 1 or 2 for data
Hi, I have just bought a ZS for my daughter and just noticed that it doesn’t have the USB just like your picture. Why did the garage say it was missing? Doesn’t make sense for it to be missing as it’s needed to connect to Apple Car Play as I understand
Sorry is this a ev gen1 or 2 or maybe a petrol?
Will power still be supplied to the two USB once the car is switched off (I don't want it to be as it would drain up the battery)
I think someone mentioned they stay on for a few minutes after the car is switched off.
Car only gets android auto through rh plug (although phone thinks it's connected through either). Charge rate is abysmal too. On android auto my phone is draining even though plugged in
