where is the charging breathing light??? zsev 2019 and other stupid questions
Ditto after 2 services.
I'm not fussed about AC charging unlocked, as where I charge (Tesco's and home) I always lock it anyway.
If it ain't broke, don't fix it. ;)
Yes Ditto doesn't bother me either as I charge 100% at home., I asked the service dept about software updates when I took it in & he asked me how everything was with it, I said it's been absolutely perfect & ne'er a problem with it. He said if it needs any updates it'll get them.
Not that it makes much difference, but why does not have a “Granny” charger in the boot ?.
All ZS EV’s where provided with the car as standard equipment.
The type 2 cable was not included, unless you had a kind dealer !.
because it was bought from motorpoint, and they did not have it, so i kept the one from my hyundai, ( it was that or reduce car by £150 )
You shouldn't need to lock to charge, dealer software update that was sorted long long ago, obviously the cars previous owner didn't bother.
yep, 4 updates outstanding so going back to motorpoint to get done, they tried to get me to sort it, but oct 19th was earliest i could get booked in. so being took away monday and courtesy car supplied, if not done, ill be getting a refund and they can have car back.
recall updates not done are
SA015
SA016
SA017
SA020
ok final update before they take car away
if i go to podpoint at tescos. it charges.
podpoint at home it does not
i have the latest podpoint , type 3? or 2
and suspect it does not handshake with car without the update
If you use any ethernet extenders it can cause problems sometimes people don't know they have them but sky use them sometimes so you can have a box in another room
Anyway if you have any switch them off then try changing
