Why is my MG EV ZS is not charging to 100%?
zapmyevnow
uk
I set my Ohme charger on MAX charge to charge on the Ohme app.
I set scheduled charging on my MG iSMART app for 12am to 5am.
Usually it charges to 100% but just recently it has only been charging to about 80%.
It’s a 2023 model.
Is the battery failing?
Are you sure 5 hours is long enough to get up to 100% ?
The car had 48% charge left before charging and it has a 51kWHr battery and I have an Ohme charger delivering at 7.4kW.
So it should it should only take about (100-48)/100 x 51 / 7.4 =3.584 hours to charge to 100%.
Theoretically the time you worked out will work, but there are losses to take into account.
It always takes more time to charge than you calculate. There are coversion losses in the charger and battery so it could be that you just need to charge for longer.
Also the batteries need to be charged to 100% and left on charge for a long time after that every now and then to equalise them.
Just checking because one contributor had this happen to them a while ago. Are you sure you haven't set an 80% charging limit in iSmart or in the Infotainment charging screen? They had inadvertently set a limit and were unaware of it.
why do you need to set MG iSMART app for 12am to 5am, can't you set the time on your charger? What is your ZS, long range or standard?
They've got a 51kWh battery, so that's going to be without the option to set the charge limit.
Have you equalised the battery lately? Mind you, it'd have to be badly out of equalisation to finish at 80% but it could happen. Maybe your ohme has a setting that has change causing it to shut off too soon.
Did this get resolved?
Early this year, my app software updated and unbeknown to me, it reset my car to max 80% charge.
I realised I was not getting the charge I wanted so looked through my car settings.
Turned out the car was set to maximum charge only to 80%.
Could it be something like that?
Rob
I recently noticed my ZS was also doing this. Very strange to be charging exactly to 80% every time, no matter how long on charge for or level of charge remaining before commencing charge. I had updated the iSmart app recently, so I went looking through the user interface and eventually found it had a setting for maximum charge, which was set to 80%. I had never accessed this menu before and wasn't even aware it existed. I'm certain it was set as a consequence of the app update, but I cannot prove it.
