DonBattino452
- Dec 25, 2025
- Herford, Germany
- MG4 (2022-2025)
Mine were between / \ and - - . Maybe I have to adjust them.
I didn't know you could rotate them, I have only been adjusting them up, down or side to side with a pin. I might try that before I try replacing the nozzles. Does it make a big difference ?@gdog I mean the positions of the nozzles. Mine were - - at first, then | | and I think / \ is the best way for my use case.
Am I right in assuming the V position is the point of view from when you are sitting in the car?The windshield washer nozzles have been bothering me ever since I got the car (2022).
Originally, they were positioned like this: "--", which only produced a small puddle of water at the bottom of the windshield.
Currently, they're positioned like this: "\/". Perfect when stationary, acceptable up to about 100 km/h, but not ideal.
I'd be grateful for any advice.
It would be the same from inside the car or standing on the outside looking at the the front.Am I right in assuming the V position is the point of view from when you are sitting in the car?
I mean is the point where they touch near the windscreen or the front of the car?It would be the same from inside the car or standing on the outside looking at the the front.
I see what you mean, I think the lines should be viewed as vertical though, in which case they look the same back or front.I mean is the point where they touch near the windscreen or the front of the car?
Option 1
Front of car
Window
Or
Option 2
Front of car
Window
Ah someone who understands my odd brainI see what you mean, I think the lines should be viewed as vertical though, in which case they look the same back or front.
Top of window
Bottom of window
