Winter coming 12V battery
Jto
Elstree
Hi all
Winter is coming and just like ICE the 12V battery needs to be monitored and a lot of people over look this. Up until last month I used my car every day and did 18 miles each week day, now I have retired the car is not used every day and also a lot of short journeys so the 12V battery may not get the charge it needs and the voltage will slowly drop and then one day the car will not start.
The cars made before the app you need to monitor by look for the status of charge in information screen, check this up on the MG website and user manual. Cars with the app can scan the car and check the 12V battery status at the bottom of the list, do this after being standing in the off and lock for 10 minutes or so.
A good 12V battery should be showing 13V, if a battery shows 12V take the car for a good run to bring it up, the 12V battery is charged when charging the HV battery but you may only do the every two to three weeks but the 12V battery is been used when the car is off so slowly discharging. You can buy a an off board charger to boost the battery.
If your car is three to four years old your battery may keep dropping to 12V more often and this is sign it’s not as efficient as it was and may be time to replace the battery before it fails on you. Before you start shouting I have had a battery on mine for 7 years the above is subject to make and build quality and use.
Your ZS should be monitoring and charging the 12v battery as needed, even when the car is off.
Thanks I know that, but over the years been on here there have been many people caught out by 12V batteries failing through not monitoring the voltage drop, the car will do the day to day but has no way to tell you the battery is failing and then the day you need the car it failed.
Some good tips here 👍.
If you suspect that your 12 volt battery status is a little low, then you don’t need to necessarily have to “take it out for a run”.
Just having the car in “ready” mode has the same effect.
ICE powered vehicles have an alternator to charge the 12 volt battery, driven by the ICE.
Going for a run is beneficial in this case.
In ready mode, the traction battery 🔋 is providing a charger to the 12 volt battery.
“Top Tip” - If you are a low user case, not covering a lot of miles, then using a smart charger a couple of times a year is a good idea.
Your 12 volt battery will love you for it 🥰.
It will limit the risk of getting caught out on the day you need the car.
A battery 🪫 booster pack is a brilliant antidote when this happens and is a good investment.
Could save a long wait for the recovery people !.
For clarity, in the MG4 you do not need to be in 'Ready' mode just powered up to charge the 12V battery from the HV battery. (The car drops out of 'Ready' mode once you leave the seat but it stays powered up until you power it down from the info screen or you lock the car.)
EDIT: Must check, it may be the car comes out of 'Ready' mode when you open the driver's door.
The MG4 also charges the 12V battery from the main battery when it's locked. I have previously posted screen shots of my battery showing 14.7V after being unused for over 24 hours on the MG4 forum. If yours doesn't then a software update might be needed.
I assume the MGS5 does the same but as the battery voltage isn't available to view on the app I can't say for certain.
It a strange thing to omit it from the health check pass on the App for the S5 ?.
12 volt battery status is an important one 🤷🏻.
Why offer the facility to check it when your IN the car, but not OUT ????.
I guess if you are a low milage user case and are concerned about keeping tabs on the 12 volt health on your S5, you might consider fitting one of these little devices onto your 12 volt battery 🪫.
Not that expensive to buy and an easy DIY job to fit in only a couple of minutes.
You install a free to download App on your phone and you’re good to go !.
You are then able to check on 12 volt battery status when you like.
It will even send a notification to your phone when the status of the battery drops to low.
Here is video showing it being installed and working.
Under the “more” tab, there is links for the unit and were to down load the App.
Mine is in right now getting a new 12v for this very reason. MG5 pre-facelift, will be 4 years old in March, no issues at all of any sort until last weekend. Stopped to charge up at Wetherby on our way to a wedding on Saturday, came back after charging and the car wouldn't start. System error and HV battery shut down showing on dashboard. AA came in about 10 minutes, by which time the car had got over itself and was fine for the rest of the weekend. But this morning the battery meter on the dash showed 13.8 on start up, rather than the usual 14, then dipped as low as 13.5 before creeping back up to 14, so it's clearly on its way out. Halfords store couldn't do it as they can't work on EVs (that's another story!), but thankfully the garage could fit me in.
It's always the same thing.
The 12 volt battery never fails when you have plenty of time on your hands, but always when you have be somewhere important AND in a hurry !.
12 volt batteries are like light bulbs, working fine one minute, then gone the next :mad:.
Many of the better quality 12 volt batteries ( Bosch / Excide etc ) usually come with 5 year warranty.
If you take this path, remember to keep the receipt for proof of purchase.
Put the receipt in a plastic bag and tape it to the side of the new battery.
You where very lucky that the rescue services just happen close by this time.
Lesson firmly learnt though my friend, strongly consider investing in a battery booster pack and keep it under the drivers seat.
My booster pack has helped a few people, who where pulling their hair out.
Stuck on a hot day, with a flat battery and a car full of screaming kids, on two occasions alone.
All ICE cars and never EV's strangely enough ?.
I like the idea of taping the guarantee to it, although it is the kind of thing I'd keep anyway. The new one comes with a 5 year guarantee so we should be good for a while now.
You can’t misplace it if it’s taped to the battery 🔋.
Remember what I said about a 12 volt battery they can fail at any time, even new one can.
Booster pack for the win 🏆!.
I keep the guarantee at home but write on the battery the date I installed it in permanent marker pen
My new HS Hybrid had a low 12v battery when I got it and I was getting iSmart warnings about braking a steering. Dealer checked for errors, there were none and said these issues can be caused by low charge on the 12v. It can also cause the infotainment system to show text in Chinese. They charged it for me and I have had no issues since. I read the forum and saw the range of issues a low charge can cause so was worried. I used the iSmart app to check the voltage and every night it said 12.1v or 12.v which seemed low. I decided to buy a battery monitor and it told me my battery was at 12.78v and never dropped below 12.69v. The state of charge is reported as being over 95%. So the iSmart app may not be accurate enough to give peace of mind.
As the app is just reading the BMS what does the information screen showing.
Much depends on where the 12V is being measured. Anywhere other than the battery terminals will include a volt drop which can be significant when you are looking at granularity of tenths of a Volt.
Studied the above posts with interest and it raised a question in my mind. I have an HS Hybrid + Trophy 2025 model and am a low mileage driver 3500 miles/yr. short shopping trips.
A jump pack sounds a good idea in my case. Questiion:- Can the jump pack be connected across the 12v battery terminals without removing the existing connections?. also battery is in the boot is there a positive and negative terminal in the engine bay, if it is impossible to open the boot.
Does the hybrid+ have a battery monitor fitted in order to send battery readings to the app? so fitting another one would be belt and braces.
My question turned into three. Hope someone knows the answers. Thanks
Yes it can. That's how they are supposed to be used and they should have a fail safe so if connected the wrong way round they won't work.
