12 volt battery
Davecut1
Bristol uk
Hi there MG4 owners, I recently had a problem with my 12 volt battery and was quoted £180 by my local dealer for a replacement. I think it's got a bit more life left in it but want to be prepared to replace it. So does anyone know the correct model number or even a better replacement at a reasonable price. Thanks Dave.
Go on fleebay and search car battery. If you enter your reg it will tell you.
I'm guessing c £60 if a bev.
I tried that and most popular models it's coming up with will not fit. I guess I will have to measure the dimensions and get the highest amp hour battery in that size.
Just for your info I have done a lot of searching on ebay and the battery required is an 063H and Yuasa do one it's also called a ybx5012 with a 5 year warranty for around £60 with free delivery. If you want a budget version Hankook also do one with 4 year warranty for around £40.
If you want to replace it, i suggest you get a lifepo4 battery. They are not much more expensive (starting around 90-100 Euros). Since there wont be any high current you can choose almost any battery. I went with a 40ah lifepo4. Since a Lithium can use 100percent of its capacity it equals around a 70-80ah lead battery .
Aren't charging voltages different? If the charger is set up for lead acid, won't that cause a problem?
The charging curve is diffrent yes, but the voltages are very Close. A 4s lifepo4 has a charging Limit of 14.6v and lead acid range fron 14.4 to 14.8. The BMS in a lifepo4 battery will prevent Obercharge.
Have lifepo4 in my Toyota Prius for 11 years now and in my mg4 for about 1.5 years. Never had the slightest issuse.
If you can access the cell terminals, add one of these HA02 induction cell balancers. They say 48v but that's just 4 12v batteries being equalised, they will equalise LFP and sodium ion cells just fine as well.
as each lead acid battery dies, I just build a 4 cell one out of the best old LFP cells I have lying around (not so many these days since the fires) and never need to worry about them again if I add a cell equaliser to keep them all working together.
You can often find them where people are replacing their tired DIY EV conversion batteries, as long as they hold voltage under load, they will be fine for aux batteries and that is all an EV needs for a 12v battery
T1 Terry
You can do that , Just alot of Work for a simple aux batt, the prebuild ones from eBay or AliExpress have balancers and BMS integrated and really arent that expensive. I think i payed around 80 eur For mine. Not Wörth the hassle to build one yourself
Sorry, this got a bit carried away, the techo in me escaped ....
Been building lithium batteries for 14 yrs now and I know what works and what doesn't, and the toy BMS and balancer in those prepacked batteries simply don't work for the capacity battery they are connected across. I've had roughly 30 brought in for me to tell them what is wrong with them and write a report as to why they failed so they could make a warranty claim.
The BMS and balancer used in these drop-in batteries was designed for push bike and toy batteries. They use a loss balance system that creates a controlled short across the cell through a resistor at a set voltage point. These resistors turn electrical energy into heat energy .... inside a sealed plastic case. They are designed to balance 1ah cells, not 40Ah cells, so when that cell voltage goes high, it will take those little resistors 20hrs to burn off 1ah .... the resulting heat build up burns out the zener diode and the resistor just remains on continuously .... eventually fully discharging the cell and because the cells can't be accessed, the battery becomes a throw away ....
The induction coil cell equalisers charge up each induction coil connected to that cell, then disconnect from the cell and link together so the voltage is equalised across the induction coils, then it links back to the cell.
If the voltage across the induction coil is higher than the cell voltage, the induction coil discharges into the cell until the induction coil and cell voltage as the same ......
If the cell voltage is higher than the induction coil voltage, it charges the coil until the voltages are the same between the cell and the coil
Then the cycle repeats
This way, any cell that is a higher voltage, discharges some of it's capacity into the cells with a lower voltage, but this takes place at cycles per second, so the cells are balanced very quickly and remain balanced when charging or discharging .....
The upper voltage for an LFP cell is 3.6v, past that and heat is being generated inside the cell, heating the electrolyte till it separates depositing rubbish across the graphite material coated plate, reducing the rate lithium ions can be collected and released, and causes the lighter elements in the electrolyte to boil off and gas, this is what causes the cells to swell .....
14.4v across a 4 cell LFP battery is 3.6v per cell if perfectly balanced, if they are not perfectly balance, at least one cell will be at a much higher voltage and another cell at a much lower voltage, a battery in the process of being murdered ....
T1 Terry
I replaced a gel battery in one of my motorcycles more than 4 years ago with a LifePo. Bike starts like new today, no issues whatsoever. I'll definitely be replacing my MG4 battery with a LiFePo when the time comes. No brainer.
@T1 Terry - Can you advise if there is a Replacement Battery, which will function well, in the MG4? Do not plan to swap the OEM one out while it is working, but would like to keep in mind a good replacement.
I sort of assume the one I have will last a while as I do not plan to use high loads, like the Starter Motor, very often. The Pb killers, IIRC, are high loads (200 A+) and discharges below 50% SOC. If I need to use AUX loads I have the V2L to use instead of the 12V battery.
So for reference, do you know of an off the shelf replacement unit?
There is a company over this way that build drop in LFP batteries that work, but they are designed as house batteries, so the size would be the problem.
It would involve you actually building it or having it built for you, but an Na+ (Sodium ion) cylindrical battery would do the job for life.
If you want to know how to build it or get it built for you, let me know and I'll post the details here
T1 Terry
Hi Terry,
I'm also looking to replace the lead-acid battery in my MG4 with something a little more modern.
I was planning on buying a few LFP cells, I found some 32aH prismatics that looked like they would work. I'm happy enough to put them in a safe and wire up the BMS also, I've done similar projects in the past.
Can I ask about the avaliability of Na+ Sodium Ion cells? I'm not really that familair with these, can they be charged just like regular LFP cells or do they need different charge settings? Can they handle similar charge and discharge currents compared to LFP? Thanks and any info on building a pack for the MG4 would be helpful too :)
Keep in mind, there are a lot of battery assemblers jumping on the band wagon of LFP popularity, but zero knowledge of what they are doing and relying on the interweb for their guidance and that just sends them in completely the wrong direction.
My wife wrote a good website in easier to understand language that spills out of my mouth, T1 Lithium | Custom-built lithium batteries for RVs and off grid This is not a commercial plug, the workshop burnt to the ground a number of yrs ago and the business is closed and I'm retired ..... really tired these days ;)
T1 Terry
I wrote a post over on your other thread Does anyone know the peak charging current of the 12v battery? that might help.
I bought the 200Ah Sodium ion cells I built our 600Ah mobile home house battery from Dinah at OSN Power, they still need to be strapped if you use prismatic cells, so cylindrical cells is probably the easiest method to build smaller capacity batteries .....
T1 Terry
