TassieDi
- Jul 8, 2022
- Location
- Tasmania, Australia
- ZS EV
I was pleased to find that the BM12V battery monitor stores its records and gives the app the history when it reconnects. Nice. I was also pleased to see that whenever I challenge the 12V (by doing an iSmart scan, for example) it returns to its original charge. So, after a day of monitoring and trying different scenarios, I am finding that the Intelligent Charging does actually work to boost the 12V battery at almost all times. i.e.
I did note with #3 that the EO Hub charger did change its status at one point for no apparent reason and the 12V declined for a little while but then recovered.
So I am currently concluding that the recent incident was due to some glitch with the EO Hub and perhaps in combination with the MG ZS. I did also notice today that the plug was a little loose in the car's socket, and on closer inspection saw that one of the metal pins is set back (see photo) - the CP pin. Is that normal? I've not noticed that before. If this is not normal, perhaps I need to get this fixed.
- when the car is at rest (Off, Locked, not Charging)(it was stable as 12.5 overnight),
- when it is Charging (boosts up to 14.2V)
- when it has stopped Charging but remains plugged in, and is Locked (stable at around 12.8)
