Why do you assume it's an MG issue? It could be just as easily a charger issue.Went to 180kw charger station...
Disappointed as I only get up to 87kwh charging speed...
Dammit mg stop giving false advertising
On the charger or in the car? In car will be lower due to losses.I’ve seen 91 at a Tesla charger in France.
In carOn the charger or in the car? In car will be lower due to losses.
do you have information for ac charging? what would be the max kwh speed for SR ac charging? was it 7kwh or 6.6 kwh?Latest information from MG now states max charge of 87Kw for the SE SR (can't find it now...)
Edit - found it on the Australian website
So if I we're to use a 32a charger.The onboard AC charger is rated at 6.6kW ... it's in the specs somewhere.
