Some further observations some 1000 miles in from the Jan 2021 BMS update.
It is still taking hours from 100% charge being reached before equalisation is completed.
Seems to have settled at 449V when fully charged and equalised with everything off. If departing at 100% but before equalisation is finished it may be displaying 447-448V.
Regen available pretty much immediately. Using max regen and you may see 452 or 453V early in a journey.
The GoM doesn't seem as linear as it was. Range seems to go down quicker than expected down until about 2 blobs (36% ish) then, after you are starting to get concerned you might not reach you destination, consumption seems to slow. I'm getting around 70 miles for first 65% of battery and 50 miles for final 35% mixed driving in N with heating on in temps near freezing.
I haven't endured any of those painful slow sub 30kW Rapid charges since the update, and have mostly been charging at 42-46kW on a 50kW charger. Maybe I have been lucky or have got the SoC and battery temperature into the goldilocks zone before attempting a rapid charge, but maybe the BMS update has improved this?
Brilliant feedback @WalkingBootWeather .
Nobody appears to have passed the 448 - 450 volt mark post latest BMS update.
It now comes to light, that MG has decided to "Peg" the max voltage at this figure now.
I have only done about six charge / balance processes and yes I agree, the balancing is taking more time than I am comfortable with.
I find the Regen is available earlier now, but as the battery level drops, it does not appear to increase in strength as much as it use too somehow.
More "Linear" ???????.
Hard to describe, but it is different from the original set up that's for sure.
We are unable to make any trips, unless we are going to the super market !.
Therefore trying to make any range comparison between "Pre & Post" updates is impossible.
On the good old original factory software, the orange warning message of low range would activate between 35 - 40 miles of remaining range on the GOM.
Is your still displaying a similar situation ?.
On longer trips ( remember them ) in the better weather, I found the GOM to be pretty accurate.
One mile of range consumed about 1 mile from the GOM.
I have absolutely NO idea how this latest update has affected this situation of course.
Never been a big supporter of charging my car all the way to the Max - unless I have a long journey to make and then use the car on the same day.
Now I find myself charging when not required, in attempt to balance the pack as recommended.
At first chasing the unicorn figure of 455 volts that has now been amended back to 450 volts.
I really am not convinced that my HV battery was badly affected by a massive loss in range, because it never had the "Buggy" software updates done.
So, why am I chasing that unicorn in my dreams ?.
Bugger that !.
I consider I have really tried to look after my HV pack over the last 12 months, now I find myself going against my better judgement and banging in charge at every opportunity under mixed messages from the manufacture.
One week the pack voltage should be 455 volts - next week it's 450 volts.
Left hand - Right hand comes to mind !.
