Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
Before I went out I tried the pre-heat, as the car was still plugged in and at 100%, and it definitely worked. Dropped the SOH down to 99%, so I knew it had done it even before I went out to check. (Previously I'd noticed that no power was being taken from the battery even when it was supposedly heating.) While the SOH was still high I tried a few smart-ish stops, and the car was fine, no noise, no vibration.
I did the hill reverse, twice, and there was no sign of anything wrong at all. No sound, no vibration, no juddering, no scraping, the car just went down the hill backwards with no fuss at all. I'm pretty dubious about this entire brakes story. Although, what do I know about it.
Then I went on a joy-ride on the same road I took when the car was new, and the LKA definitely wasn't driving me to distraction this time. A few beeps but very little pulling on the wheel at all, even when I turned the sensitivity up to high on the way back. And that was on a winding road where you tend to cross the centre line on the bends. My impression was that if the line wasn't terribly clear it was just ignoring it.
The speed limit recognition was just as terrible as always, seeing what it shouldn't be seeing and sometimes not seeing what it should have seen. But the A701 is particularly bad for this, with big signs warning HGVs that they're limited to 40 mph shortly after almost every "national speed limit" indication, and of course the car sees that, and of course it flashes 40 at you for the next 20 miles. It was also seeing some 20 mph signs relating to side roads, and it completely missed the "national speed limit" sign exiting Broughton, because it's dirty and partly overhung by branches. But then it was always thus.
I'm encouraged enough to leave off the pre-flight check-list for now and see how I get on.
So the bottom line is that, assuming they fix the door handle next week as arranged, everything I wanted done has actually been done this time. If they'd been a bit pleasanter to me and hadn't tried to upsell me £2,000 worth of what I suspect is make-work, they might have been in with a chance. As it is, after Friday of next week I hope never to see them again.
